[OpenLayers-Users] getFeatureInfo request in new window + new map?
Eric Lemoine eric.c2c at gmail.com
Wed Jan 23 02:33:59 EST 2008
With MapServer passing mapfile variable values as GET params can be
done, even with WMS I've been told. Check the MS doc.
2008/1/23, Maria Panagou <snowdrop at ath.forthnet.gr>:
> is it possible to use variable substitution in a layer creator url,in a
> header template file (getfeatureinfo) such as:
>  var quakes = new OpenLayers.Layer.WMS( "Óçìáíôéêïß Óåéóìïß",
>                        "http://127.0.0.1/cgi-bin/mapserv.exe?",
>                         {map: '../htdocs/mpanagou/Quakes1local.map',
>                           layers: 'Quakes',ID=[codee]
> 						  transparent: true},
>                           {isBaseLayer:false, singletile:true, reproject:
> true});
> where ID is filter condition, [codee] attribute from getfeatureinfo.
> in map file, layer quakes is defined by:
> DATA "pos FROM (select * from public.quake_small where codee1=%ID%) as foo
> using unique codee1 using SRID=4326"
> in OL, the declaration of quakes as following works:
>                           layers: 'Quakes',ID=721
> 						  transparent: true},
> true});
> but i want id to be set dynamically as the value of codee attribute returned
> by getfeatureinforequest
> thank you
> http://www.nabble.com/getFeatureInfo-request-in-new-window-%2B-new-map--tp15009098p15032612.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
