[OpenLayers-Users] Map backgroundimage
Till Adams adams at terrestris.de
Fri Jan 25 09:21:15 EST 2008
Xavier Rayo schrieb:
> I have a map that needs a lot of time to be loaded and i would like to
> know if there is any possibility to add a background image to the map,
> with an image that shows what you'll see in the map, while the  map is
> loading. In that way the user would not appreciate the loading time.
> Is it possible?
> Does anybody knows a way to accelerate my map?
> thanks,
> xavi
> Express yourself instantly with MSN Messenger! MSN Messenger
> <http://clk.atdmt.com/AVE/go/onm00200471ave/direct/01/>
>_______________________________________________
>Users mailing list
>Users at openlayers.org
>http://openlayers.org/mailman/listinfo/users
Xavier,
1) there are kinds of start/end event you can dedicate to every object.
    just send a div to the map until the specific layer finished
(end-event) loading.
see also: http://openlayers.org/pipermail/trac/2007-July/002265.html
2) It might be helpful, if you would talk a little bit more about WHAT
kind of map-service is slowly (UMN, WMS, WFS, Text, .... ??)
Best regards, Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
