[OpenLayers-Users] Map backgroundimage
Xavier Rayo
ivaxoyar at hotmail.com
Fri Jan 25 09:32:00 EST 2008
In my map i'm using two services,
one is a text layer wich works so fast and has no problems, and another with wms layers, using mapserver, wich is the one that is very slow.
In the ticket you told me, speaks about wfs layers, can it be use with wms layers? do you know any example where i can see how to use it?...
thanks!!
xavi
> Date: Fri, 25 Jan 2008 15:21:15 +0100> From: adams at terrestris.de> To: ivaxoyar at hotmail.com> CC: users at openlayers.org> Subject: Re: [OpenLayers-Users] Map backgroundimage> > Xavier Rayo schrieb:> > >> >> >> >> > I have a map that needs a lot of time to be loaded and i would like to > > know if there is any possibility to add a background image to the map, > > with an image that shows what you'll see in the map, while the map is > > loading. In that way the user would not appreciate the loading time. > > Is it possible?> > Does anybody knows a way to accelerate my map?> > > > thanks,> > > > xavi> >> > ------------------------------------------------------------------------> > Express yourself instantly with MSN Messenger! MSN Messenger > > <http://clk.atdmt.com/AVE/go/onm00200471ave/direct/01/>> >> >------------------------------------------------------------------------> >> >_______________________________________________> >Users mailing list> >Users at openlayers.org> >http://openlayers.org/mailman/listinfo/users> > > >> Xavier,> > 1) there are kinds of start/end event you can dedicate to every object.> just send a div to the map until the specific layer finished > (end-event) loading.> see also: http://openlayers.org/pipermail/trac/2007-July/002265.html> > 2) It might be helpful, if you would talk a little bit more about WHAT > kind of map-service is slowly (UMN, WMS, WFS, Text, .... ??)> ;-)> > Best regards, Till> > > ----------------------------------------------------------> terrestris GmbH & Co. KG> Irmintrudisstrasse 17> 53111 Bonn> Germany> > Till Adams> Geschäftsführung> > Tel: +49 (0)228 / 962 899-52> Fax: +49 (0)228 / 962 899-57> adams at terrestris.de > http://www.terrestris.de> Amtsgericht Bonn, HRA 6835> ---------------------------------------------------------> > Komplementärin:> > terrestris Verwaltungs GmbH> > vertreten durch:> Hinrich Paulsen, Till Adams> > >
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080125/96c0b77f/attachment.html
