[OpenLayers-Users] Map backgroundimage
Lance Dyas lancelot at inetnebr.com
Fri Jan 25 09:33:49 EST 2008
I would like to see the load start and load end reflected in the
LayerSwitcher
if nothing else make a className style change for a layers listing ;-)
Till Adams wrote:
> Xavier Rayo schrieb:
>> I have a map that needs a lot of time to be loaded and i would like to
>> know if there is any possibility to add a background image to the map,
>> with an image that shows what you'll see in the map, while the  map is
>> loading. In that way the user would not appreciate the loading time.
>> Is it possible?
>> Does anybody knows a way to accelerate my map?
>> thanks,
>> xavi
>> Express yourself instantly with MSN Messenger! MSN Messenger
>> <http://clk.atdmt.com/AVE/go/onm00200471ave/direct/01/>
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Xavier,
> 1) there are kinds of start/end event you can dedicate to every object.
>     just send a div to the map until the specific layer finished
> (end-event) loading.
> see also: http://openlayers.org/pipermail/trac/2007-July/002265.html
> 2) It might be helpful, if you would talk a little bit more about WHAT
> kind of map-service is slowly (UMN, WMS, WFS, Text, .... ??)
> Best regards, Till
> terrestris GmbH & Co. KG
> Irmintrudisstrasse 17
> 53111 Bonn
> Germany
> Till Adams
> Geschäftsführung
> Tel: +49 (0)228 / 962 899-52
> Fax: +49 (0)228 / 962 899-57
> adams at terrestris.de
> http://www.terrestris.de
> Amtsgericht Bonn, HRA 6835
> Komplementärin:
> terrestris Verwaltungs GmbH
> vertreten durch:
> Hinrich Paulsen, Till Adams
> Users mailing list
