[OpenLayers-Users] Map backgroundimage
Till Adams
adams at terrestris.de
Fri Jan 25 09:39:00 EST 2008
Xavier,
sorry, I have no visible example, we use a kind of that for logging the
access to our client.
to 2)
The performance for UMN is highly customable, so I think it would be
good to post your exact configuration, data-source, etc. to the
UMN Users list (or tell it to me and I'll have a quick look, but be
fast, weekend is coming closer!)
> In my map i'm using two services,
> one is a text layer wich works so fast and has no problems, and
> another with wms layers, using mapserver, wich is the one that is very
> slow.
> In the ticket you told me, speaks about wfs layers, can it be use with
> wms layers? do you know any example where i can see how to use it?...
> thanks!!
> xavi
> > Date: Fri, 25 Jan 2008 15:21:15 +0100
> > From: adams at terrestris.de
> > To: ivaxoyar at hotmail.com
> > CC: users at openlayers.org
> > Subject: Re: [OpenLayers-Users] Map backgroundimage
> > Xavier Rayo schrieb:
> > > I have a map that needs a lot of time to be loaded and i would
> like to
> > > know if there is any possibility to add a background image to the
> map,
> > > with an image that shows what you'll see in the map, while the map is
> > > loading. In that way the user would not appreciate the loading time.
> > > Is it possible?
> > > Does anybody knows a way to accelerate my map?
> > > thanks,
> > > xavi
> > > Express yourself instantly with MSN Messenger! MSN Messenger
> > > <http://clk.atdmt.com/AVE/go/onm00200471ave/direct/01/>
> > >_______________________________________________
> > >Users mailing list
> > >Users at openlayers.org
> > >http://openlayers.org/mailman/listinfo/users
> > Xavier,
> > 1) there are kinds of start/end event you can dedicate to every object.
> > just send a div to the map until the specific layer finished
> > (end-event) loading.
> > see also: http://openlayers.org/pipermail/trac/2007-July/002265.html
> > 2) It might be helpful, if you would talk a little bit more about WHAT
> > kind of map-service is slowly (UMN, WMS, WFS, Text, .... ??)
> > Best regards, Till
> > terrestris GmbH & Co. KG
> > Irmintrudisstrasse 17
> > 53111 Bonn
> > Germany
> > Till Adams
> > Geschäftsführung
> > Tel: +49 (0)228 / 962 899-52
> > Fax: +49 (0)228 / 962 899-57
> > http://www.terrestris.de
> > Amtsgericht Bonn, HRA 6835
> > Komplementärin:
> > terrestris Verwaltungs GmbH
> > vertreten durch:
> > Hinrich Paulsen, Till Adams
terrestris ist umgezogen!
Die neue Adresse ab 01.07.2007 lautet:
Irmintrudisstraße 17, 53111 Bonn
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
