[OpenLayers-Users] Weird IE offset problem with vector layer...
SOLVED
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Jul 2 20:45:02 EDT 2008
It turns out the table cell holding the map div had align=center and that was enough
to throw things out of whack in IE. I updated my test case to show the problem just in
case anyone thinks this is a bug in OL and not just a quirk in IE.
Steve
>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 07/01/08 11:11 PM >>>
Hi folks: I'm converting an older application that uses table layouts to OL (v. 2.6) and have everything working nicely except for an issue with a vector layer. I've setup a simple measure function using the draw feature control. In IE however the feature is offset in the x direction from the actual mouse position by 100+ pixels, there is no y offset. The mouse move event handler seems to be reporting the correct mouse position it's just that the vector feature itself is displaced.
I don't have permission to share the app with the world as yet. I did try to create a test case but haven't been able to recreate the problem with a simple example. A link to the test case is:
http://qpublic5.qpublic.net/fl_nassau/ol/test.html
It shows the general application layout. The map itself stretches or shrinks to fill the space between fixed interface elements. Again, the test works in IE. It starts with the area control active. Imagine the vector feature a hundred pixels to the right of the mouse and you've got a good picture of how this is broken in the main app. Works fine in Firefox and Safari. I've tried IE6 and 7 on XP.
Any ideas on what could cause such a shift?
Steve
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
