[OpenLayers-Users] Geocoding in Spherical mercator
David Martinez Morata damarmo at gmail.com
Thu Jul 3 09:30:45 EDT 2008
Thanks for your help.
Diego I try this:
    function showAddress(address) {
       var geocoder = new GClientGeocoder();
     if (geocoder) {
       geocoder.getLatLng(
         address,
         function(point) {
           if (!point) {alert(address + " not found");}
           else
{map.setCenter(OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y),15)}
And thats Works. Thanks!
2008/7/3 Paul Spencer <pagameba at gmail.com>:
> Try this:
> var mapProj = new OpenLayers.Projection('EPSG:900913');
> var userProj = new OpenLayers.Projection('EPSG:4326');
>    if (geocoder) {
>        geocoder.getLatLng(
>            address,
>            function(point) {
>                if (!point) {
>                } else {
>                    var ll = new OpenLayers.LonLat(point.x,point.y);
>                    ll.transform(userProj, mapProj);
>                    map.setCenter(ll,15);
> Cheers
> Paul
> On 3-Jul-08, at 8:07 AM, David Martinez Morata wrote:
>  Hello.
>> I have a problem with geocoding.
>> I have a function to do it, but the problem its the result. I geocode and
>> the result it's in EPSG:4326 projection but mi map it's in EPSG:900913. I
>> try to put the transform function of OpenLayers.LonLat object but I'm doing
>> somthing wrong.
>> My function it's:
>>     if (geocoder) {
>>       geocoder.getLatLng(
>>         address,
>>         function(point) {
>>           else {map.setCenter(new OpenLayers.LonLat(point.x,point.y),15)}
>> Anyone can help me?
>> Thanks
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080703/e2314ae6/attachment.html
