[OpenLayers-Users] 'list' object has no attribute 'value' when
adding wfs layer
Ed Fialkowski
edfialk at gmail.com
Thu Jul 3 14:33:30 EDT 2008
Hi all, I have an openlayers app up at http://pocus.wustl.edu/wfs with a wfs
layer that retrieves data from featureserver.
At one point, this was working. There's no telling what I've done but I
can't figure it out.
So, once you click 'update map', the wfs layer is added (appears in layers
tab), but javascript throws an error:
Error: syntax error
Source File: http://pocus.wustl.edu/wfs/
Line: 1, Column: 1
Source Code:
An error occurred: 'list' object has no attribute 'value'
line 1 column 1, great. It's definitely triggered on map.addLayer(wfs);
The important parts are in the function UpdateMap():
//get variables and form url
wfs = new OpenLayers.Layer.WFS("WFS", url, {maxfeatures: 3000,
typename: 'topp:multipolygon'}, {ratio: 1.0, extractAttributes: true});
wfs.preFeatureInsert= function(feature){
features["\""+feature.fid+"\""] = feature;
var co = parseInt(feature.attributes['value']); ///there
is a feature.attributes['value'], don't think it's this but I guess it might
be
if (co > scales[4])
feature.style.fillColor="red";
else if (co > scales[3])
feature.style.fillColor="#E79518";
else if (co > scales[2])
feature.style.fillColor="#A8F257";
else if (co > scales[1])
feature.style.fillColor="#00F2AE";
else if (co > scales[0])
feature.style.fillColor="#1A95E5";
else
feature.style.fillColor="blue";
fcount++;
//feature.style.fillOpacity=0;
wfs.events.register("loadend", wfs, "hide_load()");
map.addLayer(wfs);
// document.write(wfs.getFullRequestString());
var select = new OpenLayers.Control.SelectFeature(wfs, {onSelect:
onFeatureSelect, onUnselect: onFeatureUnselect});
map.addControl(select);
select.activate();
wfs.getFullRequestString() prints out a functional request that I can
straight paste and get XML
example:
http://pocus.wustl.edu/cgi-bin/featureserver3/featureserver.cgi/GIS?format=WFS&issum=true¶m=CO&value=100&BBOX=-95.922852,35.402222,-89.880371,41.851196&maxfeatures=3000&typename=topp%3Amultipolygon&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326
(It takes a little over a minute for the SQL to return and featureserver to
print, but it does eventually print)
Anyone have any ideas what list object is trying to access a value but
can't, and why it's thrown immediately upon adding the layer to the map?
I would just be unbelievably grateful for any and all help.
Thanks!
-Ed
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080703/8c66f96e/attachment.html
