[OpenLayers-Users] GeoRSS
Eric Lemoine
eric.c2c at gmail.com
Fri Jul 4 13:46:11 EDT 2008
Yes, you can't use the GeoRSS layer. Your code isn't correct, remove
the new, what you pass to the layer is the class object, not a class
instance. Eric
2008/7/4, Fabio D'Ovidio <fabiodovidio at gmail.com>:
> Hi!
> I read openlayers 2.6 improved GeoRSS Format support, including GeoRSS
> GML read support
> http://trac.openlayers.org/wiki/Release/2.6/Announce/Final
> I assume, in order to display polygon and line GeoRSS, I must create an
> OpenLayers.Layer.Vector layer with the features created from the feed
> using OpenLayers.Format.GeoRSS.read.
> I can't use OpenLayers.Layer.GeoRSS. Is it right?
> Could another solution be as following?
> var georssformat = new OpenLayers.Format.GeoRSS;
> var gmllayer = new OpenLayers.Layer.GML("Test", "rss.xml",
> {'format': georssformat});
> Thanks
> Paul Spencer ha scritto:
>> Please check the OpenLayers examples that come with the source
>> package, you will find everything you need.
>> On 3-Jul-08, at 5:02 AM, Fabio D'Ovidio wrote:
>>> Hi!
>>> Does OL support GeoRSS polygon and\or line geometries in the new
>>> version?
>>> Any example?
>>> Ing. Fabio D'Ovidio
>>> INOVA Open Solutions s.r.l.
>>> Web : http://www.inovaos.it
>>> Tel.: 081 197 57 600
>>> mail: fabiodovidio at gmail.com
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
