[OpenLayers-Users] Firefox performance issues on Windows
Matt Williamson
MatthewDW at gmail.com
Tue Jul 8 09:44:45 EDT 2008
zspitzer,
Thanks for the report...but really? As I told someone else, I'm only
getting about 2 frames per second in map drawing (dragging, panning)
in FF2 and FF3 on windows...you're getting much better than that?
Yeah, I'm not happy with the control set (trying to solve a very
complex problem with just one map, and so I may make some significant
UI changes...). I haven't yet figured out how to configure (modify?)
the SelectFeature control to allow dragging to pass through while
still registering clicks on the vector layer. If you could point me to
an example, that would be terrific!
-Matt
On Jul 8, 2008, at 1:35 AM, realjax wrote:
> Works ok here too, in FF2 on windows.
> The map ,IMHO doesn't 'feel' right.. I would change the handler on the
> vectors, so panning (grabbing) the map is also possible when the
> mouse is
> over a vector, but that is just my two cents.
> Other then that, no issues here!
> zspitzer wrote:
>> Works fine for me in FF3 on windows...
>> did you try firefox in safe mode, ie with no add-ons running?
>> z
>> On Tue, Jul 8, 2008 at 7:14 AM, Matt Williamson <MatthewDW at gmail.com>
>> wrote:
>>> Hello list,
>>> I wrote a while back about this, but I was having a bit of trouble
>>> reliably reproducing it, and I didn't have the page up and publicly
>>> accessible yet...now I have both.
>>> The page below works great in Safari 3/Mac, Safari 4DP/Mac, IE7/Win,
>>> Firefox 2/Mac and Firefox 3/Mac/Linux. But it is dog slow in
>>> Firefox 2
>>> and Firefox 3 on Windows. Panning/dragging is stuttery to the
>>> point of
>>> being nearly unusable, and in some cases even moving the mouse over
>>> the map can stutter, and seems to spin the CPU unnecessarily. This
>>> is,
>>> for example, on a Core 2 Duo system with plenty of RAM. At first I
>>> thought it had to do with the Vector layers, but it seems to do
>>> mostly
>>> the same thing with the vector layers turned off.
>>> Any ideas as to what's causing the problem would be extremely
>>> appreciated!:
>>> http://www.wrh.noaa.gov/pih/firewx/maps.php?area=Central%20Idaho
>>> Thanks!
>>> -Matt
>>> P.S.: Probably unrelated, but I think I also have something wrong
>>> with
>>> my scales/resolutions or something, because double-clicking the map
>>> would change the center to some place far south of the click (so I
>>> disabled double-click)...if anyone notices something wrong that
>>> might
>>> cause this, that would be great to know too!
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
>> Users mailing list
> View this message in context: http://www.nabble.com/Firefox-performance-issues-on-Windows-tp18326762p18333566.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
