[OpenLayers-Users] Combine DrawFeatureControl with standard map
behaviour
Alan Boudreault
aboudreault at mapgears.com
Fri Jul 11 08:38:28 EDT 2008
Hi Kristen,
I think only one control can be activated on the map at the same time.
The reason is simple, they all have differents mouse handlers and
behaviors. You'll need to propose a toolbar or something to let the user
choose the control he wants to use. (see this example:
http://www.openlayers.org/dev/examples/draw-feature.html ) If you really
need to get both behaviors... you can easily create a new control, or
overide some drawfeature functions to support shift+drag.
Regards,
Alan
Kirsten Grimm [geOps] wrote:
> Hello,
> I have a DrawFeatureControl which is activated by default.
> Now, i still want the standard map behavior to work, for example
> Shift+Mousedrag for a zoombox, or double click for zooming.
> What is the standard way to implement this, is there an example somewhere?
> I have tried around with custom Controls and Handlers, but had no success.
> thanks in advance,
> Kirsten
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alan Boudreault
Mapgears
http://www.mapgears.com
