[OpenLayers-Users] Using openlayers in portlet
Frédéric Therrien
fredth at hotmail.com
Fri Jul 11 09:16:51 EDT 2008
Ok, I found something, in fact, you were right, in my portlet.html ,I have 2 dtd and these doesn't allow the display. If I take them off, I can see my page. The only problem is, I'm not sure if I can remove them in my portlet. For the second one, there's no problem, but for the first one, I'm not sure. Do you have any idea of the kind of the doctype I should use ? An example I mean.
Thx
Fred
> Date: Fri, 11 Jul 2008 07:40:32 -0400> To: fredth at hotmail.com> CC: users at openlayers.org> Subject: Re: [OpenLayers-Users] Using openlayers in portlet> From: crschmidt at metacarta.com> > On Thu, Jul 10, 2008 at 04:25:27PM -0400, Frédéric Therrien wrote:> > > > Hey everyone, I'm pretty new with openlayers and I have a question.> > > > For my job, I need to user openlayers to display a map in a bea portal application (in other words, in a portlet). My jsp page is attached. If I run this page in my index.jsp, it's working fine, I see my world map and I'm pretty happy, but when I put it in my portlet's jsp, I can't see nothing. > > > > In fact, I use firefox so with firebug, I've watched what kind of requests are done and I see all the call to the mapserver and they return the good stuff so I don't understand why my map isn't rendred in my portlet. Do you know any issues with openlayers and portlets ?> > Compare the HTML of the generated pages. I bet in the latter case, you> have some kind of doctype that's different -- possibly a strict HTML> doctype. If so, you might not have a CSS rule like "html, body { height:> 100% }" -- and in XHTML, that might mean that your map ends up with no> height. (You can check this with map.getSize() -- in fact, checking that> first might be your best bet.)> > -- Chris> > > I use:> > Java 5.0> > BEA Weblogic 10.0.1> > Windows> > MapServer 4> > my map are in a shapefile> > my map file is ok> > > > Can you help me please.> > > > Thx a lot> > > > Frédéric Therrien> > > > > > > > _________________________________________________________________> > Envoie un sourire, fais rire, amuse-toi! Employez-le maintenant!> > http://www.emoticonesgratuites.ca/?icid=EMFRCA120> > > _______________________________________________> > Users mailing list> > Users at openlayers.org> > http://openlayers.org/mailman/listinfo/users> > > -- > Christopher Schmidt> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080711/5813d40a/attachment.html
