[OpenLayers-Users] read Format.GeoRSS from http request
bartvde at osgis.nl
bartvde at osgis.nl
Mon Jul 14 04:03:14 EDT 2008
Fabio,
leave out the new keyword before OpenLayers.Format.GeoRSS.
Wrt proxy, please read:
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#HowdoIsetupaProxyHost
Best regards,
Bart
> Christopher Schmidt ha scritto:
>> I didn't suggest using a Layer.GeoRSS. I suggested using a Layer.GML
>> with a Format.GeoRSS.
>> Regards,
> Hi!
> I'm trying as following:
> function test3 () {
> var urlObj = "http://127.0.0.1:80/myapp.php?";
> var test = new OpenLayers.Layer.GML("GeoRSS", urlObj, {format:
> new OpenLayers.Format.GeoRSS({'xy': true})});
> map.addLayers([test]);
> The errors are:
> * Error in loading GML file on http://127.0.0.1:80/myapp.php?
> * this.format is not a constructor
> var gml = this.format ? new this.format(options) : new
> OpenLayers.Format.GML(options);
> in GML.js
> About the first one i think the problem is related to
> OpenLayers.ProxyHost. How can I set it using OpenLayers from
> 127.0.0.1:8085?
> Consider that var urlObj = "http://127.0.0.1:80/myapp.php?" is the
> output of an xaction inside Pentaho BI application that runs on Jboss.
> It works, there are no problems about it, but I need to use OL from
> Jboss while myapp.php runs on 127.0.0.1:80.
> Thanks again!
> Ing. Fabio D'Ovidio
> INOVA Open Solutions s.r.l.
> Web : http://www.inovaos.it
> Tel.: 081 197 57 600
> mail: fabiodovidio at gmail.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
