[OpenLayers-Users] the center of origin in a grid
Ignacio Gámez Ramírez ignacio.gamez at geograma.com
Tue Jul 22 02:36:55 EDT 2008
Hi, someone knows why the origin of the center in the grid (width tile) Is the left bottom corner?
Geograma S.L.
Topografía, Cartografía y Sistemas de Información Geográfica
Teléfono: 902.995.584
www.geograma.com
www.geoservicios.com
-----Mensaje original-----
De: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] En nombre de Eric Lemoine
Enviado el: martes, 22 de julio de 2008 7:51
Para: Dipl. Inf. Carsten Eider; openlayers users
Asunto: Re: [OpenLayers-Users] Splitting a polygon
Yes, you can probably rely on double click, the click handler might
help you with that, see the corresponding example. Eric
2008/7/22, Dipl. Inf. Carsten Eider <eider at fh-bingen.de>:
> Hi Eric,
> multiple:false sounds good, i will try it.
> Any idea how to define the end of modification? May the user should do a
> doubleclick ?
> Carsten
> Eric Lemoine schrieb:
>> Hi. It is a bit hard to help you with so few details but i'll give it
>> a try. You can pass clickout:false to the modify feature control to
>> disable feature un-selection on clickout. To disable multi-selection
>> pass multiple:false. I'm not sure that will help... Eric
>> 2008/7/21, Dipl. Inf. Carsten Eider <eider at fh-bingen.de>:
>>> hi folks,
>>> my work a an openlayers-based geoeditor goes on.
>>> One of my features i have to developed ist to split a polygon.
>>> This is my actual solution:
>>>    1. Select polygon
>>>    2. Select one existing point of the feature
>>>    3. Select second one
>>>    4. Split feature on server backend
>>> I would like to be able to split the feature by a variable linestring:
>>>    1. Select polygon
>>>    4. Modify linestring
>>>    5. Define end of modification:Split feature on server backend
>>> Upto 5. my solution works: I add a modifyfeature.control
>>> but now the trouble starts:
>>> How can i prevent that other features (another polygon) are selected or
>>> my polygon i unselected when i click outside of it
>>> How can i detect the end of my modification, maybe by an doubleclick ?
>>> Thx Carsten
>>> Mit freundlichen Grüßen / Yours faithfully
>>> Carsten Eider
>>> Dipl. Inf. (FH)
>>> Kompetenzzentrum für Innovative Informationssysteme
>>> c/o Fachhochschhule Bingen / University of applied sciences Bingen
>>> Berlinstraße 109
>>> 55411 Bingen
>>> Tel: +49 (0) 6721 / 409-179
>>> Fax: +49 (0) 6721 / 409-158
>>> email: eider at fh-bingen.de
>>> Internet: iis.fh-bingen.de
> Carsten Eider
> Dipl. Inf. (FH)
> Berlinstraße 109
> 55411 Bingen
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
