[OpenLayers-Users] proj4js question
Christopher Schmidt crschmidt at metacarta.com
Wed Jul 23 10:17:06 EDT 2008
On Wed, Jul 23, 2008 at 10:15:43AM -0400, Mike Adair wrote:
> Yes that check was put in there for the case where the last point in a
> polygon is the same object as the first one to prevent it from getting
> transformed again.  It is safe to remove that, but that also means
> application logic will have to account for it for polygons, i.e. loop
> over coordinates array length minus 1.
OpenLayers does this appropriately, for what it's worth, though I'll
admit it took a couple times of doing it wrong to get it right :)
> It seems like that is causing more trouble than it is worth and I will
> remove it when I prepare a 1.0 version of Proj4js.
Cool, thanks.
Regards,
Christopher Schmidt
MetaCarta
