[OpenLayers-Users] extra div
Bilge Tutak bilge.tutak at gmail.com
Thu Jul 24 17:08:47 EDT 2008
Yes, I suspected the same thing. Therefore I removed every possible
styling and dimensions from the parent div. It is just a pure div. May
be it is the problem? Do I have to give it some dimensioning? However,
this still does not explain the problem with tables.
On Thu, Jul 24, 2008 at 4:56 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Hi. Sounds like a CSS problem to me. Does your new div have dimensions
> (height and width)? Hope i'm on the right track... Eric
> 2008/7/24, Bilge Tutak <bilge.tutak at gmail.com>:
>> Hi,
>> I have a simple openlayers map, actually the simplest example from the
>> examples. I tried to put, the "map" div into another div or table.
>> When I do this, the map just disappears when I look at the page in IE.
>> I can see the map in Firefox. Is there a reason for this to happen?
>> Thanks,
>> Bilge.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
