[OpenLayers-Users] Include drop down box in popup that contains query result
S.Reena reena at indiamail.com
Sun Jul 27 18:25:06 EDT 2008
I am still not very sure of this...Here is the code of my pop up...Can you
tell me where exactly I need to make modifications....
               Here I have made one drop down box and I want that when one
element is selected in this....second drop down box having the query results
should come beside it...
function search()
		popup = new OpenLayers.Popup.Anchored("search",
                                new OpenLayers.LonLat(78.46881,11.46881),
                                  new OpenLayers.Size(200,125),
 	"Enter the Information:<br /><br \><div id=\"test\" class=\"pop\"
style='font-size:.8em'>District:&nbsp\;&nbsp\;<select id=dname><option
selected value=\"\">Select...</option><option value=cu>Cu</option><option
value=ma>Ma</option><option value=na>Na</option><option
value=si>Si</option><option value=th>Th</option><option
value=th>Thr</option></select><br><br><center><input type=button
value=\"OK\" onclick=\"update()\"> </center><br/>",null, true);
popup.autoSize=true;
popup.setBackgroundColor("#23238E");
popup.setOpacity(0.9);
map.addPopup(popup);
Thanks in advance.
Cheers,
Reena.
Arnd Wippermann wrote:
> Hi,
> you can do it on server-side with templates or client-side with
> javascript.
> Server-side:
> Create html templates for your query:
> A Header template with:
> <select>
> A body template with:
> <option value="[item1]">[item2]
> And a Footer template with:
> </select>
> Then your query returns the HTML for a drop down box.
> Client-side:
> Create a body template that returns a list of the results:
> [item1],[item2],[item3]
> Then your query returns text, which you can transform with javascript into
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von S.Reena
> Gesendet: Sonntag, 27. Juli 2008 11:37
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] Include drop down box in popup that contains
> query result
> I have made popup in UMN openlayers. I want to make a dynamic drop down
> box
> in it that shows result of the  postresql database query. Can any one
> guide
> me up as to what to use..Python or something else..
> Cheers,
> Reena.
> http://www.nabble.com/Include-drop-down-box-in-popup-that-contains--query-re
> sult-tp18674744p18674744.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Include-drop-down-box-in-popup-that-contains--query-result-tp18674744p18681306.html
