[OpenLayers-Users] Zooming with multiple kamap layers
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Tue Jul 29 10:48:37 EDT 2008
Alexandre,
Thanks for the tip - I think I might have tried setting isBaseLayer, but
placed the parameter in the wrong argument. Newbie mistake I guess.
Regards,
Mike
Alexandre Dube wrote:
> Hi Mike,
> Both your layers are base layers. Only one base layer can be displayed
> at a time. It is wrong to set the visibility to true to an other base
> layer.
> Just add isBaseLayer: false to your second layer and it will become an
> overlay. Or add the layerSwitcher control to switch the base layer.
> Here's your modified code. I use the "get some info" button to help me
> keep track of some important infos about my layers. Hope this helps.
> Alexandre Dube
> Mapgears
> adube at mapgears.com
> <html>
> <head>
> <title>OpenLayers Example</title>
> <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
> <script type="text/javascript">
> var map;
> function init(){
> var options = {
> controls: [],
> maxExtent: new OpenLayers.Bounds(-180,-90,180,90),
> scales:
> [100000000,50000000,25000000,10000000,5000000,2500000,1000000],
> numZoomLevels: 8,
> tileSize: new OpenLayers.Size(200,200),
> projection: "EPSG:4326",
> units: "dd"
> map = new OpenLayers.Map('map',options);
> var ly1 = new OpenLayers.Layer.KaMap(
> "World Map",
> "http://clima.ominiverdi.org/ka-map/htdocs/tile.php",
> i:"JPEG",
> map:"cvs",
> g:"World Map",
> version:"6"
> var ly2 = new OpenLayers.Layer.KaMap(
> "Places",
> i:"PNG",
> map:"cvs",
> g:"Places",
> version:"6"
> isBaseLayer: false
> map.addLayers([ly1,ly2]);
> map.zoomToExtent(new OpenLayers.Bounds(-180,-90,180,90));
> map.addControl(new OpenLayers.Control.Navigation());
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.PanZoomBar());
> map.addControl(new OpenLayers.Control.MousePosition());
> //ly2.setVisibility(true);
> // Bouton get some info
> function disp_alert()
> var i;
> var sToAlert = "";
> if (map.layers){
> for (i=0;i<map.layers.length;i++) {
> sToAlert += i + " : ";
> if (map.layers[i].params != null) {
> sToAlert += map.layers[i].params.layers + "\n";
> else if (map.layers[i].isVector) {
> sToAlert += "Layer de type Vector" + "\n";
> sToAlert += " isBaseLayer : " + map.layers[i].isBaseLayer;
> sToAlert += " inRange : " + map.layers[i].inRange;
> sToAlert += " Visibility : " + map.layers[i].getVisibility();
> sToAlert += " Projection : " + map.layers[i].projection;
> sToAlert += "\n";
> alert(
> "Left : " + map.getExtent().left + "\n" +
> "Bottom : " + map.getExtent().bottom + "\n" +
> "Right : " + map.getExtent().right + "\n" +
> "Top : " + map.getExtent().top + "\n" +
> "Scale : " + map.getScale() + "\n" +
> "Projection : " + map.getProjection() + "\n" +
> "Nb de layers direct : " + map.layers.length + "\n" +
> "Map center : " + map.getCenter() + "\n" +
> "\n" + sToAlert
> </script>
> </head>
> <body onload="init()">
> <div style="width:50%; height:50%" id="map"></div>
> <input type="button" id="disp_alert" onclick="disp_alert()"
> value="get some info" />
> </body>
> </html>
> Mike Leahy wrote:
>> Ok - here's a better demonstration of this problem. Copy this into an
>> html file...open it in a browser, then zoom in. You'll see what I'm
>> talking about. This is using the World Map and Places layers from one
>> of the ka-map demos hosted by omniverdi.org. Is it something I'm
>> doing wrong with the OL code, or maybe a bug in OL's kamap layer object?
>> Regards,
>> Mike
>> <html>
>> <head>
>> <script
>> </head>
>> <body>
>> <div style="width:100%; height:100%" id="map"></div>
>> <script defer="defer" type="text/javascript">
>> var options = {
>> scales:
>> numZoomLevels: 8,
>> units: "dd"
>> var map = new OpenLayers.Map('map',options);
>> var ly1 = new OpenLayers.Layer.KaMap("World Map",
>> {i:"JPEG",map:"cvs",g:"World Map",version:"6"}
>> var ly2 = new OpenLayers.Layer.KaMap("Places",
>> {i:"PNG",map:"cvs",g:"Places",version:"6"}
>> </script>
>> </body>
>> </html>
>> Mike Leahy wrote:
>>> Hello list,
>>> I've been working on an application that uses Ka-Map, but
>>> I think I might consider adopting OpenLayers for the
>>> client-side part. I have been able to setup a map that
>>> loads two layers (see sample HTML below). When the map
>>> initially starts, I call roads.setVisibility(true);, and I
>>> see the roads layer overlaid on top of the aerial
>>> photography layer. It looks fine at that point...panning
>>> works fine. Once I zoom in or out, however, the base
>>> layer (the photography) does what is expected, but the
>>> roads layer just defaults to its original extent, and
>>> remains at the initial zoom level. Is there something I
>>> need to do to tie the roads layer to the zoom event?
>>> If this is a known issue, or if I'm just missing
>>> something, maybe someone can point me in the right
>>> direction. I'm using OpenLayers 2.6 (should I try
>>> SVN?). The tile.php script is something that I have
>>> integrated into my application on the server - it's
>>> generally based on the one from kamap (checked out of svn
>>> about a month ago), but I don't think it's the source of
>>> this issue (i.e., if I make the roads layer the base
>>> layer on its own, it works fine).
>>> Thanks in advance for any help,
>>> Mike
>>> <html>
>>> <head>
>>> <script
>>> src="https://localhost/application/js/lib/OpenLayers.js"></script>
>>> </head>
>>> <body>
>>> id="map"></div>
>>> var options = {
>>> maxExtent: new
>>> OpenLayers.Bounds(1327479,4883397,1415461,5034462),
>>> scales:
>>> [200000,150000,100000,75000,50000,25000,10000,5000],
>>> numZoomLevels: 8,
>>> tileSize: new OpenLayers.Size(400,300),
>>> units: "m"
>>> var map = new
>>> var aerials = new
>>> OpenLayers.Layer.KaMap("mymap",
>>> "https://localhost/application/tile.php",
>>> {layers:"0",i:"AGG_JPEG",map:"mymap",g:"Aerial
>>> Photography",sid:"somesessionid"}
>>> var roads = new
>>> {layers:"160",i:"alpha",map:"mymap",g:"Roads",sid:"somesessionid"},
>>> {numZoomLevels:8,scales:
>>> [200000,150000,100000,75000,50000,25000,10000,5000]}
>>> map.addLayers([aerials,roads]);
>>> OpenLayers.Bounds(1373558,4988812,1404038,5011460));
>>> </script>
>>> </body>
>>> </html>
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
