[OpenLayers-Users] listener on zoom
Alexandre Dube
adube at mapgears.com
Tue Jul 29 15:01:41 EDT 2008
Eric,
After trying this and that, I found out how it works. Buy thank you
anyway, Eric.
Actually, I used the Scale Control as my example, because I though
"It does the same thing !" ( change a value each time we zoom ). But, I
found out that this control uses moveend instead of zoomend. Is there a
reason for that ? To recalculate the scale after panning doesn't look
very useful to me. What do you think ?
Again, thank you very much Eric,
Alexandre
Eric Lemoine wrote:
> On Tue, Jul 29, 2008 at 5:48 PM, Alexandre Dube <adube at mapgears.com> wrote:
>> Hi everybody,
>> I want to disable and enable html form elements at a certain scale.
>> Can I register an event listener my map when it resizes ?
>> I saw map.events.listeners.resize and also ...zoomend. Can I use
>> those ? If so, how ? Or is there an other way to do it ?
> It seems to me that you indeed want the register to the zoomend map event.
> Eric
Alexandre Dubé
Mapgears
www.mapgears.com
