[OpenLayers-Users] stitch together multiple maps?
Andrew de Klerk
andrew.deklerk at gmail.com
Thu Jul 31 10:55:57 EDT 2008
Wendell
If I understand you correctly, you want to display your images as a mosaic
of tiles. This question was asked last week, and the answer was to setup a
raster WMS, that serves the images. Chris provided some links (see below)
for doing it with mapserver (which we have found to excellent at serving
images). The gdal tileindex utility can create a shapefile grid of all the
images, you then simply reference that shapefile in your mapserver map file,
and mapserver will find the appropriate image and display it
http://mapserver.gis.umn.edu/docs/howto/raster_data
You'll then set up a WMS Server:
http://mapserver.gis.umn.edu/docs/howto/wms_server
Andrew
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Lance Dyas
Sent: 31 July 2008 03:22 PM
To: openlayers user list
Subject: Re: [OpenLayers-Users] stitch together multiple maps?
Wendell Turner wrote:
> I have several GeoTIFF images and each shows up just fine
> (by itself, using gdal2tile to break them up).
> How do I use OpenLayers to show a patchwork of maps? That
> is, the left edge of one is the right edge of the other; the
> bottom of one is the top of yet another, etc. In fact, I
> have lots of these that form a mosaic of a given area.
> Should I use gdalxxx to put them together to form one (very
> large) map and then use gdal2tile to break it up,
If you are using the gdal library a handy method I have found to create such
a very large mosaic is using gdals vrt format... then use it as a source for
the gdal2tiles process. A vrt is an xml that describes the combination
multiple source files which are then read from as though one file by other
gdal processes
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.5.9/1583 - Release Date: 7/31/2008
6:17 AM
