[OpenLayers-Users] drawing shape gets offset when window expands
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Thu Jul 31 11:23:19 EDT 2008
Chris,
Thanks for the response. I am using OL 2.6. The issue occurs not when
the map window is resized (it stays the same), but when it's location is
moved over on the page to accept a larger block of text in an adjacent
table cell.
I currently do not have the ability to demonstrate on an external server
(some time tomorrow or later today I will get that going).
Thanks for any insight,
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Thursday, July 31, 2008 9:37 AM
To: Burgholzer,Robert
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] drawing shape gets offset when window
expands
On Thu, Jul 31, 2008 at 09:23:21AM -0400, Burgholzer,Robert wrote:
> I have an ajax based application that edits the properties on objects,
> and uses an openlayers window as a means to supply KML shapes for
those
> objects. Sometimes, when editing an object, due to property value
> widths, the normal property editing div resizes when it loads data.
> When this happens, the OL window is shifted over, and then drawing
> registration is offset. That is, the lines appear offset from the
mouse
> pointer, making drawing quite challenging.
> Any ideas what might be happening here? (Using FF2)
I'm somewhat surprised that this is happening in OL2.6, but you didn't
mention what version you're actually using... so I don't know what
Any time your map size changes, call map.updateSize(). This should clear
out the event caches, and make your mouse position/line drawing correct
again.
Reproducing a small example where it doesn't if it doesn't work would be
good.
Regards,
Christopher Schmidt
MetaCarta
