[OpenLayers-Users] Addition of grid
Paul Spencer pagameba at gmail.com
Thu Jun 12 07:18:59 EDT 2008
Hi Kusum,
Producing maps in different projections is not part of OpenLayers
mandate - it just displays them.  OpenLayers doesn't really care about
projections much, so its pretty easy to pull in maps that are in
different projections.  You just need to know some stuff about what
you are pulling in.
* when creating a new OpenLayers.Map instance, you can specify a
projection parameter in the options to say what projection the map is
in - this is not absolutely necessary, OpenLayers will not use this to
reproject your map, but it can be used with some controls to reproject
output of, say mouse coordinates, from the map projection into
something more recognizable (usually lon/lat values).  You probably
need to include proj4js (http://proj4js.org/) if you want to reproject
coordinates.
* you should specify the 'units' for the map (or the base layer)
correctly.  OpenLayers assumes a unit value of 'dd' (decimal degrees)
but projected maps often have units in 'm' (meters) or 'ft' etc.  It
depends on the projection of the map, this is something you have to
know.
* you should specify the minResolution and maxResolution, and the
maxExtent of the map (or the base layer).  Resolution is a measure of
ground units per pixel.  The defaults are reasonable for decimal
degrees so if your projection is not in decimal degrees then the
defaults will be wildly wrong and you'll have problems.  Same for
maxExtent (by default this is new OpenLayers.Bounds(-180,-90,180,90))
As to examples, I suggest that you spend some time reviewing the
extensive examples provided with the source - there are several
examples of working with maps in other projections (specifically with
SphericalMercator projection)
Cheers
Paul
On 12-Jun-08, at 1:26 AM, Kusum wrote:
> Hii All
> Can somebody please suggest me how to add grid on map??
> Also how can we change projection of map??
> please provide path of some example or some code for help as I have
> already messed a lot with this.
> Regards
> Kusum
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
