[OpenLayers-Users] [OpenLayers-Dev] OL-Based GeoEditor
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Fri Jun 13 08:30:52 EDT 2008
For step 1) The Openlayers example "./examples/select-feature.html" shows how to select a vector feature.
For step 2-3, ,f you are using postgis server side, there was a thread recently on the PostGIS listserv that involved some code for splitting a polygon with a line.  I think this might work for you.  Since you already have the capability to draw new shapes you may wish to change steps 2-3 to:
2) draw a line
and then simply use the function from PostGIS to split your selected polygon.
The thread pertaining to this is here:
http://postgis.refractions.net/pipermail/postgis-users/2008-May/019892.html
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] On Behalf Of Dipl. Inf. Carsten Eider
Sent: Friday, June 13, 2008 4:25 AM
To: users at openlayers.org; dev at openlayers.org
Subject: [OpenLayers-Dev] OL-Based GeoEditor
Hi folks,
i am working on a small geo-editor for an agricultural project in rhine-palatinat/germany, visit http://www.agroconnect.de for more information.
Upto now my editor has the following features:
*         new polygon, plain OL
*         edit polgon, plain OL
*         delete polygon, plain OL
*         union polygon, OL with a javaserver in the backend
Coming feaures:
*         split polygon into 2 elements, OL with server backend
*         group polygons
At the moment i am hanging a bit with the split-feature.
My idea is
1.      select polygon
2.      select first point/vertix as starting point
3.      select second point as ending point
4.      do split
5.      remove polygon and add the new ones
Step 4 will be done on serverside,but could also be done on clientside.
Any ideas how to realize steps 1-3. Should i use several controls (Select and Modify) or
should i subclass Control.ModifyFeature ?
Any hints will be appreciated.
Mit freundlichen Grüßen / Yours faithfully
Carsten Eider
Dipl. Inf. (FH)
Kompetenzzentrum für Innovative Informationssysteme
c/o Fachhochschhule Bingen / University of applied sciences Bingen
Berlinstraße 109
55411 Bingen
Tel: +49 (0) 6721 / 409-179
Fax: +49 (0) 6721 / 409-158
email: eider at fh-bingen.de
Internet: iis.fh-bingen.de
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080613/b96f5729/attachment.html
