[OpenLayers-Users] SAXParsing error in OpenLayers and/or Geoserver
Zer hcan at hotmail.com
Fri Jun 13 15:11:56 EDT 2008
Dear List,
When I send the following request from OpenLayers to Geoserver, I receive an
error message regarding SAXParsing ("document structures must start and end
within the same entity"). I have tried to sent this request using both POST
and GET, but I receive the same error. The strange part is that when I try
the same request from Geoserver's DeomRequest page, everything is fine. If i
type in the request URL into the web browsers address field, I also receives
a correct GML!  When checking then request parameters in Firefox, it seems
like the Filer parameter is cut off just at the first "="-sign.
Is the Filter parameter not encoded correctly? Or is there i bug somewhere?
If so, in OpenLayers och Geosever?
Request:
http://10.0.1.2:8080/geoserver/wfs?request=GetFeature&version=1.0.0&typeName=topp:states&outputFormat=GML2&FILTER=<Filter
xmlns=\"http://www.opengis.net/ogc\"
xmlns:gml=\"http://www.opengis.net/gml\"><Intersects><PropertyName>the_geom</PropertyName><gml:Point
srsName=\"EPSG:4326\"><gml:coordinates>-74.817265,40.5296504</gml:coordinates></gml:Point></Intersects></Filter>
Error  msg:
"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<ows:ExceptionReport
version=\"1.0.0\"\n  xsi:schemaLocation=\"http://www.opengis.net/ows
http://10.0.1.2:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd\"\n
xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"
xmlns:ows=\"http://www.opengis.net/ows\">\n  <ows:Exception
exceptionCode=\"NoApplicableCode\"
locator=\"org.vfny.geoserver.util.requests.readers.XmlRequestReader\">\n
<ows:ExceptionText>org.xml.sax.SAXParseException: XML\n      document
structures must start and end within the same\n      entity. XML document
structures must start and end\n      within the same
entity.</ows:ExceptionText>\n  </ows:Exception>\n</ows:ExceptionReport>\n"
Thanks,
-Z
View this message in context: http://www.nabble.com/SAXParsing-error-in-OpenLayers-and-or-Geoserver-tp17830193p17830193.html
