[OpenLayers-Users] [OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #1483: ModifyFeature control makes SelectFeature control to modify features
Oscar Fonts oscar.fonts.lists at gmail.com
Mon Jun 16 12:51:44 EDT 2008
As ticket says, the code to register events:
this.layer.events.on({  "featureselected": this.selectFeature,
  "featureunselected": this.unselectFeature,
  scope: this
Should be moved from "initialize" to "activate" methods, and:
this.layer.events.un({   "featureselected": this.selectFeature,
   scope: this
from "destroy" to "deactivate".
Working at http://www.icc.cat/vissir2/js/vissir_lib/ModifyFeature.js.
Oscar.
2008/6/16 Dipl. Inf. Carsten Eider <eider at fh-bingen.de>:
> Has anyone developed a solution or found a workaround?
>> features
>>  Reporter:  openlayers             |       Owner:  tschaub
>>     Type:  bug                    |      Status:  new     Priority:  minor
>>                  |   Milestone:         Component:  Control.ModifyFeature  |
>>     Version:  2.6 RC1
>>  Keywords:                         |       State:
>>  If I add ModifyFeature and SelectFeature controls to a map and connect
>>  them to the same layers, selection too becomes modification tool. When I
>>  select a feature with SelectFeature control I can see and change
>>  modification points(vertex) around the feature. The problem seems to be
>> on
>>  ModifyFeature control. It connect events to the layer when it is
>>  initialized instead of when it is activated. Should those events be
>>  connected and disconnect on activate and deactivate operations instead? I
>>  attached a file that demonstrates this bug, it is modified from modify-
>>  feature.html example. Create polygon and click "select" radiobutton and
>>  select created polygon from map.
> Mit freundlichen Grüßen / Yours faithfully
> Carsten Eider
> Dipl. Inf. (FH)
> Kompetenzzentrum für Innovative Informationssysteme
> c/o Fachhochschhule Bingen / University of applied sciences Bingen
> Berlinstraße 109
> 55411 Bingen
> Tel: +49 (0) 6721 / 409-179
> Fax: +49 (0) 6721 / 409-158
> email: eider at fh-bingen.de
> Internet: iis.fh-bingen.de
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080616/c8f4e580/attachment.html
