[OpenLayers-Users] Help with 2.6 strokeWidth and strokeweight on linestring on IE
Linda Rawson linda.rawson at gmail.com
Wed Jun 18 10:54:52 EDT 2008
Please see this post ->
http://openlayers.org/pipermail/users/2008-June/006154.html for example.
 Thanks,
Linda
 On Wed, Jun 18, 2008 at 4:24 AM, Andreas Hocevar <andreas.hocevar at gmail.com>
wrote:
> Can you please provide a stripped down example that shows the problem?
> Regards,
> Andreas.
> On Tue, Jun 3, 2008 at 11:02 PM, Linda Rawson <linda.rawson at gmail.com>
wrote:
>> I am just getting back to trying to get my application to run in 2.6.
>> I cannot see linestring vector objects at the lowest scales.  I am
>> beating my head against the wall.  I get some of them to show up,
>> those with only 4 points by setting the StrokeWidth to 1 on the style.
>> The rest....don't work.  I step through the code.  At these lines in
VML.JS
>> if (options.isStroked) {
>>            node.setAttribute("strokecolor", style.strokeColor);
>>            node.setAttribute("strokeweight", style.strokeWidth + "px");
>>        } else {
>>            node.setAttribute("stroked", "false");
>> node.getAttribute("strokeweight") before is 0.75.  On the first zoom
>> levels it changes to "1px".  Anytime I zoom further it will not change
>> the value of strokeweight no matter how hard I try to change the value
>> using hardcoded attributes or whatever.
>> What has changed in this area between version 2.5 and 2.6.  Where is
>> .75 coming from?  Where can I override that?
>> Linda Rawson
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Linda Rawson
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080618/d336f3d5/attachment.html
