[OpenLayers-Users] Not image in IE
David Martinez Morata damarmo at gmail.com
Tue Jun 24 07:59:58 EDT 2008
Thanks for the answers for my question, but now...
I don't have a error message in IE, but I don't have the image too!!!
This is my script:
    <script type="text/javascript">
        // make map available for easy debugging
        var map;
        // avoid pink tiles
        OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
        //OpenLayers.Util.onImageLoadErrorColor = "transparent";
        function init(){
            var options = {numZoomLevels: 20,
               projection: new OpenLayers.Projection("EPSG:900913"),
               displayProjection: new OpenLayers.Projection("EPSG:4326")};
               //units: "m",
               //maxResolution: 156543.0339,
               //maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
               //                                 20037508, 20037508.34),
              // Create a map Object
            map = new OpenLayers.Map('map', options);
            // Create Google Mercator layers
            var gmap = new OpenLayers.Layer.Google(
                "Google Streets");
            var gsat = new OpenLayers.Layer.Google(
                "Google Satellite",
                {type: G_SATELLITE_MAP});
            var ghyb = new OpenLayers.Layer.Google(
                "Google Hybrid",
                {type: G_HYBRID_MAP});
            var gphy = new OpenLayers.Layer.Google(
                "Google Physical",
                {type:
G_PHYSICAL_MAP});
//                Create a WFS Sites Layer
                    var sites = new OpenLayers.Layer.WFS( "Sites",
http://10.192.160.133/cgi-bin/mapserv.exe?map=/ms4w/apps/Test/WFS_Test.map",
               {typename: "Sites",maxfeatures: 100 },{
               featureClass: OpenLayers.Feature.WFS });
//                    Create a WFS Cables Layer
                    var cables = new OpenLayers.Layer.WFS( "Cables",
               {typename: "Cables", maxfeatures: 100});//,{
               //featureClass: OpenLayers.Feature.Vector});
            map.addLayers([gsat, gmap,  ghyb, gphy, sites, cables]);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.addControl(new OpenLayers.Control.ScaleLine);
            map.addControl(new OpenLayers.Control.MousePosition());
           if (!map.getCenter()) {map.zoomToMaxExtent()}
    function changezoom(x,y,z)
    map.setCenter(new OpenLayers.LonLat(x, y), z);
    function showAddress(address) {
       var geocoder = new GClientGeocoder();
     if (geocoder) {
       geocoder.getLatLng(
         address,
         function(point) {
           if (!point) {alert(address + " not found");}
           else {map.setCenter(new OpenLayers.LonLat(point.x,point.y),15);}
Thanks for help me!
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080624/75b75546/attachment.html
