[OpenLayers-Users] GeoRSS format limits to 4k size the XML node into FF
Simone Gadenz simone.gadenz at jrc.it
Wed Jun 25 11:53:41 EDT 2008
Hi all,
probably you guys knew that Firefox has a limit of 4k on XML node content. I
have just realised because some of the lines I had loaded from a GeoRSS file
were cut after 4096 chars.
I have been said to use the line[0].textContent instead of the
line[0].firstChild.nodeValue but it works only in FF and not in IE.
How did you cope with it?
Thanks
Simone
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080625/c84c59c9/attachment.html
