[OpenLayers-Users] changing div size and openlayers size command
Chris Adams chris at genieknows.com
Wed Jun 25 13:56:00 EDT 2008
Correction:
var div = OpenLayers.Util.getElement("map");
div.style.width = width + "px";
div.style.height = height + "px";
map.updateSize();
Chris Adams wrote:
> If you want the map size to change with the window, then you'll need to
> set at least the height of your body and html tags to 100%. Otherwise, I
> think you should be able to set pixel values directly to the div in
> order to resize.
> I.e.
> html, body {
>  width: 100%;
>  height: 100%;
> #map {
>  width: 100%;
>  height: 100%
> To set your size using JS:
> MilesTogoe wrote:
>> having trouble with OpenLayers in terms of window sizing.  What is the
>> correct way to specify the relationship between the div and the size
>> command in OpenLayers, especially when it goes into a div that may
>> change size according to any changes in the browser window size.
>> I have tried without much success:
>> #map {
>> width: 100%;
>> height: auto;
>> function init() {
>> map = new OpenLayers.Map('map');
>> map.Size(100%,100%);
>> layer1 = new OpenLayers.Layer.Image('citymap','/static/maps/citymap.png',
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
