[OpenLayers-Users] I'm stupid?
David Martinez Morata damarmo at gmail.com
Thu Jun 26 09:20:45 EDT 2008
Hy list, I start With OL " dais ago :S and I don't know javascript :SS!!
But I start to developing some simple application... And at the first time
was easy to  start (copy paste the code)...
But now I have some problems with a gml layer, and I have the impression tha
OL it's not more stable (maybe because I don't know javascript)...
It's my 5 or 6 email to the list asking for a the same question. Problem
with GML layer pan, they change the coordinates?!!!
I start to play with projections and now the problem it's bigger.
When I change the base layer... the map changes too!!!
I don't understand anything:S this is the code i write:
<!DOCTYPE html "-//W3C//DTD XHTML 1.0 Strict//EN"
  "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
  	<title>Test OpenLayers</title>
    <meta http-equiv="content-type" content="text/html; charset=utf-8"/>
    <script type="text/javascript"
src='http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAu_VBBdBvqz5BLcs7nrzUXBTtRbNeTxVoAy20KSc4Ig34aflRRhQFn5FeqUpODActln3OKR2UQ_14vg'></script>
src="http://openlayers.org/api/OpenLayers.js"></script>
		<script type="text/javascript">
        // make map available for easy debugging
        var map;
        // avoid pink tiles
        OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
        OpenLayers.Util.onImageLoadErrorColor = "transparent";
        function init(){
            var options = {numZoomLevels: 20,
               projection: new OpenLayers.Projection("EPSG:900913"),
               displayProjection: new OpenLayers.Projection("EPSG:4623")};
              // Create a map Object
            map = new OpenLayers.Map('map', options);
            // Create Google Mercator layers
            var gmap = new OpenLayers.Layer.Google("Google
Streets",{type: G_NORMAL_MAP},{"sphericalMercator": true});
            var gsat = new OpenLayers.Layer.Google("Google
Satellite",{type: G_SATELLITE_MAP},{"sphericalMercator": true});
            var ghyb = new OpenLayers.Layer.Google("Google
Hybrid",{type: G_HYBRID_MAP},{"sphericalMercator": true});
            var gphy = new OpenLayers.Layer.Google("Google
Physical",{type: G_PHYSICAL_MAP},{"sphericalMercator": true});
//                Create a WFS Sites Layer
	           var sites = new OpenLayers.Layer.WFS( "Sites",
               "http://10.192.160.133/cgi-bin/mapserv.exe?map=/ms4w/apps/Test/WFS_Test.map",
               {typename: "Sites",maxfeatures: 100 },{
               featureClass: OpenLayers.Feature.WFS});
           map.addLayer(new OpenLayers.Layer.GML("GML",
           	"http://10.192.160.133/OpenLayers/ngo9_wgs84_01meu_cables_lille32.gml",
            {format: OpenLayers.Format.GML,
            formatOptions: {
            	extractStyles: true,
              extractAttributes: true}
              },{projection: new OpenLayers.Projection("EPSG:4623")}
            map.addLayers([gmap,gsat,ghyb,gphy,sites]);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.addControl(new OpenLayers.Control.ScaleLine);
            map.addControl(new OpenLayers.Control.MousePosition());
           if (!map.getCenter()) {map.zoomToMaxExtent()}
    function changezoom(x,y,z)
    map.setCenter(new OpenLayers.LonLat(x, y), z);
    function showAddress(address) {
       var geocoder = new GClientGeocoder();
     if (geocoder) {
       geocoder.getLatLng(
         address,
         function(point) {
           if (!point) {alert(address + " not found");}
           else {map.setCenter(new OpenLayers.LonLat(point.x,point.y),15);}});}}
  </script>
</head>
<body onload="init()">
  <div id="header">
    <h1 id="title">Test OpenLayers</h1>
    <form action="#" onsubmit="showAddress(this.address.value,
this.countrycode.value); return false" >
  		<p>Recherchez un adresse: <input type="text" size="60"
id="address" value="" />
    	&nbsp; <input type="submit"
onclick="showAddress(document.getElementById('address').value); return
false;" value="Go!" />
    	</p>
    </form>
  </div>
  <div style="width:100%; height:85%" id="map"></div>
  <div id="docs">
 	</div>
</body>
</html>
And I don't know Wat to do...
PLeeeeeeeeeeeeaaaaseeeeee help me!
Thanks a lot for your patience!
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080626/ef0b77bf/attachment.html
