[OpenLayers-Users] TextLayer with Framecloud popup
Carl Morgan carl.r.morgan at noaa.gov
Fri Jun 27 14:28:59 EDT 2008
I'm attempting to get my points to plot based on the example Christopher
referenced (http://openlayers.org/dev/examples/sundials.html). Although
it appears to plot ok initially, if I pan up and down on the map, the
points will move up or down as well. Is this a problem in the javascript
or could the problem be in the kml file? I've included the code below
hoping someone might see the problem, and here's a link to the page:
http://www.erh.noaa.gov/ilm/viewer/plotLSR.html?lat=34.20&lon=-78.8&zoom=8&kmlfile=lsr080626.kml
<http://www.erh.noaa.gov/ilm/viewer/plotLSR.html?lat=34.20&lon=-78.8&zoom=8&kmlfile=lsr080626.kml>
Thanks,
Carl
        function init(){
            map = new OpenLayers.Map('map');
            var gmap = new OpenLayers.Layer.Google(
                "Google Streets" // the default
//            var ghyb = new OpenLayers.Layer.Google(
//                     "Google Hydrid",
//                      {type: G_HYBRID_MAP}
            map.addLayer(gmap);
            map.addLayer(new OpenLayers.Layer.GML("Reports",
"archive/LSR/KML/lsr080626.kml",
                format: OpenLayers.Format.KML,
                formatOptions: {
                  extractStyles: true,
                  extractAttributes: true
             selectControl = new
OpenLayers.Control.SelectFeature(map.layers[1],
                {onSelect: onFeatureSelect, onUnselect: onFeatureUnselect});
            map.addControl(selectControl);
            selectControl.activate();
        function onPopupClose(evt) {
            selectControl.unselect(selectedFeature);
        function onFeatureSelect(feature) {
            selectedFeature = feature;
            popup = new OpenLayers.Popup.FramedCloud("chicken",
feature.geometry.getBounds().getCenterLonLat(),
                                     new OpenLayers.Size(100,100),
                                     "<h2>"+feature.attributes.name +
"</h2>" + feature.attributes.description,
                                     null, true, onPopupClose);
            feature.popup = popup;
            map.addPopup(popup);
        function onFeatureUnselect(feature) {
            map.removePopup(feature.popup);
            feature.popup.destroy();
            feature.popup = null;
Christopher Schmidt wrote:
> On Wed, Jun 25, 2008 at 02:28:20PM -0700, Andrew de klerk wrote:
>> Ok, please forgive my late night googling skills (tired eyes!), and thanks
>> for the prompt response. If i look at that link you have said:
>> "Generally, the answer is 'no, and why are you still using a Layer.Text?
>> Use a Layer.GML with a format: OpenLayers.Format.Text and a
>> selectFeature control instead.'
>> The reason why I am using Layer.text is because I specifically don't want my
>> end users to have to select a tool to click on a feature/marker.
> They shouldn't need to.
> var control = new OpenLayers.Control.SelectFeature(layer);
> map.addControl(control);
> control.activate();
> Now the select control is active, and clicks on the features will
> activate a popup.
> See, for example: http://openlayers.org/dev/examples/sundials.html
> Regards,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080627/be300d34/attachment.html
