[OpenLayers-Users] include quesry in data source in map file
Paul Spencer pagameba at gmail.com
Sat Jun 28 10:24:53 EDT 2008
this is definitely the wrong list for this question, you should be
asking on mapserver-users or even the postgis list.
In any case, the correct way to specify a sub-select for postgis is:
DATA "the_geom from (select * from my_table WHERE name like 'abc') as
foo using unique gid using srid=-1"
Things to note:
your sub-select must return the_geom, gid and any other attributes
that you are using elsewhere (for labelitem, classitem, etc).
gid might be called something else, it just needs to be a unique value
such as the primary key of your table.
Cheers
Paul
On 28-Jun-08, at 7:14 AM, Reena Singh wrote:
> I want to use query in the map file like ........
> DATA "the_geom FROM my_table WHERE name like 'abc' "
> but this is not working accr to the format.
> Can ne1 hlp?
> Be Yourself @ mail.com!
> Choose From 200+ Email Addresses
> Get a Free Account at www.mail.com!
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
