[OpenLayers-Users] OpenLayers Question: Google Physical Projections and epsg:26915
Paul Spencer pagameba at gmail.com
Sat Jun 28 10:46:27 EDT 2008
Take a look at the spherical_mercator.html example in the OpenLayers
examples.  I'm not sure, but I think you should be adding a projection
and units to your map options
map = new OpenLayers.Map(
   'map',
     maxResolution: 'auto',
     maxExtent: new
OpenLayers.Bounds(184056.505,4809728.25,767381.245,5478975.75),
     projection: new OpenLayers.Projection("EPSG:900913"),
     units: "m"
Note that your mapserver WMS will then need to be set up to serve EPSG:
900913 correctly too, see the mapserver WMS Server how to for metadata
relating to this.
The other thing you should confirm is that your maxExtent is defined
in spherical mercator units and not in the UTM coordinates of your
data (assuming this is the same example as your postgis question on
the mapserver list) - it looks okay to me but it is very hard to tell :)
Cheers
Paul
On 27-Jun-08, at 7:23 PM, Matthew Pettis wrote:
> Hi All,
> I added the projection from http://spatialreference.org/ref/user/google-projection/mapfile/
>  into my mapfile.  I then used the file below.  The weird thing is
> that I am getting a google maps projection, but instead of for
> Minnesota (which is where my ol_ms layer gets me, I get some region
> of Europe between Barcelona, Sp and Marseilles, Fr.  Any further
> suggestions?
> Thanks,
> Matt
> <html xmlns="http://www.w3.org/1999/xhtml">
>   <head>
>     <title>OpenLayers Example</title>
> <!--    <script src="http://www.openlayers.org/api/OpenLayers.js"></
> script> -->
>     <script src="http://localhost/_common//OpenLayers-2.6/OpenLayers.js
> "></script>
>     <script src="http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAytPEybOjkPfSINF9aqMnSRRV_Z48x51l4m6KiJWs2Yue7BruuxS9q420SXqAbRhYk8GzmgwCugf2Fw
>       type="text/javascript"></script>
>     <script type="text/javascript">
>         var map = null;
>         function init(){
>                 'map',
>                     , maxExtent: new
>             var ol_ms = new OpenLayers.Layer.MapServer(
>                 "Mapserver Untiled"
>                 , "http://localhost/cgi-bin/mapserv.exe?map=C:\\ms4w\
> \Apache\\htdocs\\ol\\map.map"
>                 , {layers: 'state'}
>                 , {singleTile: true}
>             map.addLayer(ol_ms);
>             var gmap = new OpenLayers.Layer.Google(
>                 "Google Streets"
>               , {sphericalMercator: true}
>             map.addLayer(gmap);
>             map.zoomToMaxExtent();
>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>     </script>
>   </head>
>   <body onload="init()">
>     <div id="map" class="smallmap" style="width:400;height:300"></div>
>   </body>
> </html>
> It is from the wellspring of our despair and the places that we are
> broken that we come to repair the world.
> -- Murray Waas _______________________________________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
