[OpenLayers-Users] Layer rendering
Carlos Pinto
cmspinto at gmail.com
Wed Mar 5 09:42:17 EST 2008
Sorry,
The line that makes it not working is another one:
var styleMap = new OpenLayers.StyleMap({
fillOpacity: 1,
pointRadius: 10
var lookup = {
0: {fillColor: "green", fillOpacity: 1, strokeColor: "green"},
1: {fillColor: "green", fillOpacity: 1, strokeColor: "green"}
styleMap.addUniqueValueRules("default", "type", lookup);
var mylayer = new OpenLayers.Layer.GML("GML",
"../KML/simples.xml");
myLayer.styleMap = styleMap; */// This one :( so the
rectangles don't appear*
map.addLayer(mylayer);
On Wed, Mar 5, 2008 at 3:35 PM, Carlos Pinto <cmspinto at gmail.com> wrote:
> Hi Andreas,
> sorry to keep bothering, but when I add this line the polygons don't
> appear :(
> var lookup = {
> 0: {fillColor: "green", fillOpacity: 0.7, strokeColor: "green"},
> 1: {fillColor: "red", fillOpacity: 0.7, strokeColor: "red"}
> // until here it is everything ok
> // when I had this line the layer doesn't show up, I imagine he don't recognize the property
> and I am using : <script src="http://www.openlayers.org/dev/lib/OpenLayers.js"></script>
> so it is version 2.6
> On Wed, Mar 5, 2008 at 3:06 PM, Andreas Hocevar <andreas.hocevar at gmail.com>
> wrote:
> > Carlos,
> > everything below is perfect, except that you need to add:
> > <ms:type>1</ms:type>
> > instead of
> > <type>1</type>
> > And yes, you should add the {styleMap: styleMap} options hash to your
> > GML layer constructor. Or, after constructing the layer, just do
> > Regards,
> > Andreas.
> > Carlos Pinto wrote:
> > > Hi all,
> > > then, if I use OpenLayers 2.6 I can use this feature, can I ask a help
> > > of how then can I link the GML with the type?
> > > and how can I format the color, transparency and set border of the
> > > polygon?
> > > can I do like this?
> > > Thanks for your help, Carlos
> > > var lookup = {
> > > 0: {fillColor: "green", fillOpacity: 0.7, strokeColor: "green},
> > > 1: {fillColor: "red", fillOpacity: 0.7, strokeColor: "green"},
> > > 2: {fillColor: "#00ffff", fillOpacity: 0.7, strokeColor: "#00ffff"}
> > > // when I had the layer how do I say to apply the rules????
> > > "../KML/myPolygons.xml"); // should I add here in the end {styleMap:
> > > styleMap}
> > > So I have put the line * <type>1</type> * in the GML:
> > > <gml:featureMember>
> > > <ms:polygon fid="2">
> > > <gml:boundedBy>
> > > <gml:Box srsName="EPSG:4326">
> > > <gml:coordinates>0.511919,47.088176
> > > 3.002191,48.882988</gml:coordinates>
> > > </gml:Box>
> > > </gml:boundedBy>
> > > <ms:msGeometry>
> > > <gml:Polygon srsName="EPSG:4326">
> > > <gml:outerBoundaryIs>
> > > <gml:LinearRing>
> > > <gml:coordinates>7.25,54.25 7.75,54.25 7.75,54.75
> > > 7.25,54.75 7.25,54.25</gml:coordinates>
> > > </gml:LinearRing>
> > > </gml:outerBoundaryIs>
> > > </gml:Polygon>
> > > </ms:msGeometry>
> > > <ms:ogc_fid>2</ms:ogc_fid>
> > > <ms:name>My box that is class1 </ms:name>
> > > * <type>1</type> *
> > > <ms:id>0</ms:id>
> > > </ms:polygon>
> > > </gml:featureMember>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080305/0c56d9c3/attachment.html
