[OpenLayers-Users] marker help with tilecache
Aco acopetko at gmail.com
Wed Mar 5 11:36:29 EST 2008
Thanks Eric for the reply,
But sorry what do you mean by mixing projections,
I know that using the layer called "ol_wms" instead of "layer" in my
javascript code that everything works fine. So when I am not caching any
tiles it works fine, but when i am then I can't add any new layers such as
markers.
Thanks for any replies,
Aleks
Eric Lemoine-3 wrote:
> Hello, you're mixing projections, which looks suspicious to me.
> 2008/3/5, Aco <acopetko at gmail.com>:
>> I am still trying to figure out this problem, please any help would be
>> appreciated.
>> I really cannot find a solution anywhere else and my biggest hope is this
>> forum.
>> Any thoughts ?
>> Thanks Again,
>> Aleks
>> Aco wrote:
>> > Hi and thanks to all the replies in advance,
>> > I am relatively new to tilecache. I have installed it on windows and it
>> > works fine, but the problem is that is when i want to add an openlayers
>> > marker, well it just doesn't display it. It displays it when I am not
>> > using
>> > tilecache to cache the image tiles.
>> > Here is my html.
>> > <html xmlns="http://www.w3.org/1999/xhtml">
>> >   <head>
>> >     <style type="text/css">
>> >         #map {
>> >             width: 100%;
>> >             height: 99%;
>> >             border: 1px solid black;
>> >     body {
>> >       padding:0px;
>> >       margin:2px
>> >     #labs {
>> >      position:absolute;
>> >      bottom:15px;
>> >      left:7px;
>> >      font-size:smaller;
>> >      z-index: 5000;
>> >     </style>
>> >     <script src="http://openlayers.org/api/OpenLayers.js"></script>
>> >     <!--<script type="text/javascript" src="C:/Tomcat6/webapps
>> > /examples/Whitesnow/js/main_actions_1.0.js"></script>-->
>> >     <script type="text/javascript">
>> >         var lon = 5;
>> >         var lat = 40;
>> >         var zoom = 5;
>> >         var points = [];
>> >         var map, layer, polygonLayer, markers, points_ring,
>> > area_of_interest_polygon, area_of_interest_feature, ol_wms, mouse;
>> >         var icon_size = new OpenLayers.Size(1700,1700);
>> >         var coords_lat = new Array();
>> >         var coords_lon = new Array();
>> >         var vector_style = OpenLayers.Util.extend({},
>> > OpenLayers.Feature.Vector.style['default']);
>> >             vector_style.strokeColor = "#7F0000";
>> >             vector_style.fillColor = "red";
>> >         function init(){
>> >             var options = {
>> >                 units: "m",
>> >             projection: 'epsg:32661',
>> >             resolutions:
>> [5500000.0,2750000.0,1375000.0,687500.0,343750.0,
>> > 171875.0,85937.5, 42968.75,21484.375,10742.1875,5371.09375,2685.546875,
>> > 1342.7734375,671.38671875,335.693359375,167.8466796875,83.92333984375,
>> > 41.961669921875,20.9808349609375,10.49041748046875],
>> >                 maxExtent: new OpenLayers.Bounds
>> > (-2200000,-712631,3072800,3840000)
>> >            var options2 = {
>> >                 units: "m",
>> >                 maxResolution: "auto",
>> >             projection: "EPSG:3573",
>> >                 resolutions: [5500000.0, 2750000.0, 1375000.0,
>> 687500.0,
>> > 343750.0, 171875.0, 85937.5, 42968.75, 21484.375, 10742.1875,
>> 5371.09375,
>> > 2685.546875, 1342.7734375, 671.38671875, 335.693359375, 167.8466796875,
>> > 83.92333984375, 41.961669921875, 20.9808349609375, 10.49041748046875],
>> > (-4000000,-4200000,3000000,3500000)
>> >             map = new OpenLayers.Map( 'map');
>> >             ol_wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>> >                           "http://labs.metacarta.com/wms/vmap0?",
>> {layers:
>> > 'basic', srs: 'epsg:42304'});
>> >              polygonLayer = new OpenLayers.Layer.Vector("Polygon
>> Layer");
>> >              markers = new OpenLayers.Layer.Markers( "Markers" );
>> >             layer = new OpenLayers.Layer.WMS( "Openlayers WMS",
>> > http://lakeice.uwaterloo.ca/TileCache-2.01/tilecache.cgi?", {layers:
>> > 'nsidc_polar', format: 'image/png' },options2 );
>> >             map.addLayer(ol_wms);
>> >           //  map.addControl(new OpenLayers.Control.Permalink());
>> >             if (!map.getCenter()) map.zoomToMaxExtent();
>> >             mouse = new OpenLayers.Control.MousePosition();
>> >             map.addControl(mouse);
>> >             // markers.clearMarkers();
>> >              //var marker = new OpenLayers.Marker(new
>> OpenLayers.LonLat(0,
>> > 0), new OpenLayers.Icon("
>> > http://lakeice.uwaterloo.ca/TileCache-2.01/target2.png", icon_size));
>> >              //markers.addMarker(new OpenLayers.Marker(new
>> > http://lakeice.uwaterloo.ca/TileCache-2.01/target2.png", icon_size)));
>> >             // markers.addMarker(new OpenLayers.Marker(new
>> > OpenLayers.LonLat
>> > (-5859.37500, -27734.37500), new OpenLayers.Icon("
>> >             map.events.register("click", map, function(e) {
>> >          if (coords_lon.length < 4) {
>> >        // alert("no");
>> >             var lonlat = map.getLonLatFromViewPortPx(e.xy);
>> >             coords_lon.push(lonlat.lon);
>> >             coords_lat.push(lonlat.lat);
>> >           // setOutputPoints();
>> >             drawUniversalSelection();
>> >       function drawUniversalSelection() {
>> >          points.length = 0;
>> >          for (var x = 0; x < coords_lon.length; x++) {
>> > OpenLayers.LonLat(coords_lon[x],
>> > coords_lat[x]), new OpenLayers.Icon("target2.png", icon_size));
>> >             points[x] = new OpenLayers.Geometry.Point(coords_lon[x],
>> > coords_lat[x]);
>> >             markers.addMarker(marker);
>> >              map.addLayer(markers);
>> >         //alert("yep");
>> >          if (coords_lon.length > 1) {
>> >             points.push(points[0]);
>> >            //   alert("yep");
>> >          points_ring = new OpenLayers.Geometry.LinearRing(points);
>> >          area_of_interest_polygon = new OpenLayers.Geometry.Polygon
>> > (points_ring);
>> >          area_of_interest_feature = new OpenLayers.Feature.Vector
>> > (area_of_interest_polygon,null,vector_style);
>> >          polygonLayer.destroyFeatures();
>> >          polygonLayer.addFeatures([area_of_interest_feature]);
>> >           map.addLayer(polygonLayer);
>> >     </script>
>> >   </head>
>> >   <body onload="init()">
>> >     <div id="map">
>> >     <div id="labs">From  http://labs.metacarta.com/ MetaCarta
>> > Labs .</div>
>> >     </div>
>> >   </body>
>> > </html>
>> > Thanks in advance,
>> > Aleks
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> View this message in context:
>> http://www.nabble.com/marker-help-with-tilecache-tp15834699p15854144.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/marker-help-with-tilecache-tp15834699p15854430.html
