[OpenLayers-Users] Invalid Argument error in IE when leaving a
page
Linda Rawson
linda.rawson at gmail.com
Tue Mar 11 10:29:40 EDT 2008
One of the things you can do is:
Tools->Internet Options->Disable Script Debugging.
Uncheck this option for both check boxes.
It will bring up the Script debugger which should tell you exactly which
line is causing the problem.
On Tue, Mar 11, 2008 at 8:26 AM, David R Robison <
drrobison at openroadsconsulting.com> wrote:
> I'm not sure. We are in the process of delivering a production version of
> a web site and I don't know if we can switch over the the trunk and what
> other issues that might create. David
> Bart van den Eijnden (OSGIS) wrote:
> I think quite some work has been done in trunk to prevent these types of
> errors.
> Are you able to check trunk?
> Best regards,
> Bart
> OSGIS, Open Source GIShttp://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: David R Robison <drrobison at openroadsconsulting.com> <drrobison at openroadsconsulting.com>
> Naar: users at openlayers.org <users at openlayers.org> <users at openlayers.org>
> Onderwerp: [OpenLayers-Users] Invalid Argument error in IE when leaving a
> page
> Datum: 11/03/08 12:22
> When I navigate off a page (in IE7) that has a map, I get a popup
> showing an Invalid Argument error. I am using OpenLayers 2.5. This error
> does not occur with FireFox. Any ideas how to prevent this error? The
> error seems to be when it is trying to remove layers from the map.
> Thanks in advance, David
> David R Robison
> Open Roads Consulting, Inc.
> 708 S. Battlefield Blvd., Chesapeake, VA 23322
> phone: (757) 546-3401
> e-mail: drrobison at openroadsconsulting.com
> web: http://openroadsconsulting.com
> blog: http://therobe.blogspot.com
> book: http://www.xulonpress.com/book_detail.php?id=2579
> Users mailing listUsers at openlayers.orghttp://openlayers.org/mailman/listinfo/users
> David R Robison
> Users mailing list
Linda Rawson
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080311/648e6360/attachment.html
