[OpenLayers-Users] Projection over the north pole (EPSG:3573)
John Bennett john.bennett at noetix.on.ca
Tue Mar 11 14:24:06 EDT 2008
I am trying to get the mouse position to display in lat/lon when using EPSG:
3573 (http://nsidc.org/data/atlas/epsg_3573.html ).  I'm using the trunk in
hope of openlayers having proj4js support.
In the following example if I use option1 with layer 'gsat' and
sphericalMercator projection everything works great, the mouse position is
displayed in lat/lon. If I use option2 with layer 'sat_north' and EPSG:3573
the mouse position is displayed in meters, but I want it displayed in
lat/lon. Is this possible?
function init(){
            var options1 = {
                projection: new OpenLayers.Projection("EPSG:900913"),
                displayProjection: new OpenLayers.Projection("EPSG:4326"),
                units: "m",
                maxResolution: 156543.0339,
                maxExtent: new OpenLayers.Bounds(-20037508,
-20037508,20037508, 20037508.34)
            var options2 = {
                projection: new OpenLayers.Projection("EPSG:3573"),
                units: "m",
                maxResolution: "auto",
                maxExtent: new
OpenLayers.Bounds(-9036842.762,-9036842.762,9036842.762,9036842.762)
            map = new OpenLayers.Map('map', options2);
            var gsat = new OpenLayers.Layer.Google(
                "Google Satellite",
                {type: G_SATELLITE_MAP, 'sphericalMercator': true}
            sat_north = new OpenLayers.Layer.WMS( "Satellite imagery MODIS",
                    "http://nsidc.org/cgi-bin/atlas_north?", {layers:
'blue_marble_01', projection: new OpenLayers.Projection("EPSG:3573")});
            map.addLayer(sat_north);
            map.addControl(new OpenLayers.Control.Permalink());
            map.addControl(new OpenLayers.Control.MousePosition());
            map.zoomToMaxExtent()
Regards,
John Bennett
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080311/69d3eb5c/attachment.html
