[OpenLayers-Users] GET mouse position
Gregor Mosheh gregor at hostgis.com
Tue Mar 11 21:49:35 EDT 2008
Tara wrote:
> Is it possible to capture the mouse position by a click event and send it to
> another page via GET (or POST or whatever)? I would like to have users click
> on the map to fill in long and lat in <input /> fields.
Sure, happens all the time. Bind an event handler to the map, and create
a callback function to handle the event. Here's an example:
map.events.register('click', map, handleMapClick);
function handleMapClick(evt) {
   // don't select the point, select a square around the click-point
   var clickbuffer = 18; //how many pixels around should it look?
   var sw = map.getLonLatFromViewPortPx(new
OpenLayers.Pixel(evt.xy.x-clickbuffer , evt.xy.y+clickbuffer) );
   var ne = map.getLonLatFromViewPortPx(new
OpenLayers.Pixel(evt.xy.x+clickbuffer , evt.xy.y-clickbuffer) );
    // open a popup window, supplying the coords in GET
     var url = click_url + '?bbox='+sw.lon+','+sw.lat+','+ne.lon+','+ne.lat;
     window.open(url,'popup');
Gregor Mosheh / Greg Allensworth, BS, A+
System Administrator
HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
