[OpenLayers-Users] possible control.clickFeature bug
Xin xin at zenpow.com
Sat Mar 15 04:28:24 EDT 2008
Yes, I am using the select feature control.
Do you mean sc.clickFeature.call(feature)? This is not working for me.
I think I know what the underlining issue might be. The link that calls
clickFeature is in a block of HTML pulled in by AJAX. It's the textual
results of the KML points. Can you see this causing any problems?
It seems this.multipleKey is not correctly set. This does look like a bug.
I'll have a closer look later.
Thanks for the help.
On 15/03/2008, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Xin, i guess you're using the select feature control. Have you tried
> using the following to call clickFeatuse : sc.clickFeature.call(sc) ?
> 2008/3/14, Xin <xin at zenpow.com>:
> > Hi,
> > I am getting this error when calling clickFeature. It is called when I
> click
> > on a link with onclick.
> > this.multipleKey has no properties
> > multipleSelect()OpenLayers.js (line 815)
> > forwardMercator(Object layer=Object data=Object)OpenLayers.js (line 814)
> > previewFeature(0)namibia.js (line 177)
> > onclick(click clientX=0, clientY=0)localhost:3000 (line 1)
> > this.select(feature);}}},multipleSelect:function(){return
> > this.multiple||this.ha...
> > The behaviour of this error is strange. Clicking on the feature
> > works.Executing the code in Firebug console. After which, clicking on
> > the trigger
> > link works.
> > On refreshing the page, the problem would come back.
> > I have just updated to the latest trunk.
> > I've been stuck with this for a couple of days now. I would really
> > appreciate any help.
> > Xin
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080315/12c80b9e/attachment.html
