[OpenLayers-Users] How to get information on clicking on
a polygon
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 17 10:29:45 EDT 2008
Try select astxt(the_geom) as wkt from mytable where ...
kusum wrote:
> this feature also uses points for a polygon and the problem is I have
> geometry of polygon and not the x y cordinates.
> Please suggest any function if there in postgres to convert the goemetry
> field to cordinates or any other method in openlayers if exists to highlight
> polygon using goemetry.
> From: "Eric Lemoine" <eric.c2c at gmail.com>
> Sent: Monday, March 17, 2008 3:30 PM
> To: "kusum" <kusum at infobase.in>
> Cc: <users at openlayers.org>
> Subject: Re: [OpenLayers-Users] How to get information on clicking on a
> polygon
>> On Mon, Mar 17, 2008 at 8:07 AM, kusum <kusum at infobase.in> wrote:
>>> Hi Eric
>>> Thanks for replying back.
>>> I am able to fetch information from database. But the problem is that I
>>> am
>>> not able to highlight the polygon on map.
>>> To highlight it on map I need all the points in it. But the database I
>>> have
>>> in postgresql has field goem and I am not getting how to convert the
>>> goem
>>> field into coordinates so that I can get points to highlight the polygon
>>> on
>>> map.
>>> field to cordinates or any other method if exists to highlight polygon
>>> using
>>> goemetry.
>> You have multiple solutions. One simple solution involves having the
>> server send the wkt string and use OpenLayers.Format.WKT to parse that
>> string.
>> Eric
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
