[OpenLayers-Users] Map Extent/Div Size
Gérald Quintana gerald.quintana at gmail.com
Wed Mar 26 07:14:44 EDT 2008
Hello,
I have a bounding box expressed in degrees and I would like the map
frame to match  this box. How can I know the CSS size ratio I should
use for the div element?
When the map is first loaded, I get a white zone between the map and
its frame (under). Is it related to the map extent/div element size
ratio doesn't match?
Thanks for your help, you have been very helpful for my previous questions,
Gérald
