[OpenLayers-Users] MapServer to OpenLayers line rendition
Aileen aileen at mapcentral.ph
Mon Mar 31 11:06:52 EDT 2008
Hi all,
Just want to follow-up on this one.
We are currently using the latest release of Mapserver, the 5.0.2 version
and Openlayers 2.5
We are having problems with rendering lines and polygons because although it
worked for us in Mapserver 4.10, we are told that there's a new syntax for
passing values to mapserver.
Currently, here's part of the url that we are using to pass to mapserver:
map_layer_class_expression=makati&map_layer_class_color=255 0 0.
We already have looked at your samples but with no avail.
Can you help us with the new syntax?
----- Original Message -----
To: "Aileen" <aileenbaylon at gmail.com>
Cc: <crschmidt at metacarta.com>
Sent: Thursday, October 11, 2007 3:46 AM
Subject: Re: [OpenLayers-Users] MapServer to OpenLayers line rendition
The OL definition suggests that you are changing the classitem and the
expression using the
4.10 syntax. In 5.0 neither of those can be changed via a URL. I took a very
conservative
approach to exposing parameters to URL configuration (perhaps too
conservative). I didn't
want folks monkeying with ...item parameters. So, you'd need to set the
classitem in the mapfile
and not try to modify it. The expression can be altered using runtime
substitutions. You could
change the whole expression by doing something like:
  EXPRESSION '%my_expression%'
and then adding &my_expression=... to the URL somehow. (I'm not sure how the
MapServer driver adds things to the submitted URL. I'd like to take
ownership of that code.) The
benefit of doing it this way is that you can apply a validation pattern (a
regex) to the runtime
substitution to make sure what is being passed is valid. I can tell you how
to expose more properties
to URL configuration if you'd like, it's a tiny change in maplexer.l and
then recompile.
So far all you're doing is drawing features using a dynamic expression. Is
that what you mean
by line rendition? I was under the impression that you were creating
features in runtime and passing
them to MapServer for rendering in the map (as opposed to using the
OpenLayers vector API). If
that's the case then you must have code someplace to add more map_ or map.
variables to the
OpenLayers layer. (note that either a _ or a . will work as a separator).
What does that look like?
Steve
>>> On 10/7/2007 at 8:57 PM, in message
>>> <024801c80952$237704f0$9601a8c0 at aileen>,
> From: Aileen
> To: Steve Lime ; users at openlayers.org
> Sent: Monday, October 08, 2007 9:25 AM
> Hi Steve!
> Thanks for your reply.
> Here's the line that is being passed to openlayers:
> var myqry = new OpenLayers.Layer.MapServer.Untiled("Map",
> "/cgi-bin/mapserv?", {map: '/hometo/maps/mymap.map', layer:'#qrylayer#',
> map_#qrylayer#_classitem:'#qryitem#',
> map_#qrylayer#_class_expression:'#q.code#', layers:"#onlayer#", format:
> 'gif', transparent:'false'});
> We are using mapserver 5.0 and Openlayers 2.4
> No pink tiles encountered. What happens is it can zoom to the right
> location
> but could not render a line.
> When we are still using mapserver 4.10, the line above is what we use and
> it
> has no problems rendering a line.
> We read the migration guide from mapserver and they changed the way they
> create a new feature:
> changing a scalebar object:
> ...&map.scalebar=UNITS+MILES+COLOR+121+121+121+SIZE+300+2&...creating a
> new
> feature...&map_layer[3]=FEATURE+POINTS+500000+1000000+END+TEXT+'A+test+point'+
> END&...
> The value is a snippet of a mapfile.  The separator used to be underscore
> _ ) now it's a plus sign (+). But eventhough we changed that according to
> the
> new standard way of creating a new feature, the line cannot still be
> rendered! Here's our url: http:/203.131.125.60/mapcentral_OL/index.cfm
> Enter
> Keyword: Quezon AvenueEnter Location: Quezon City
> Click on any "View Map" from the Search Result.The keyword you entered is
> a
> street, so it should highlight the street that it searched. But instead,
> it
> just zooms to the location.How could this be?
>   From: Steve Lime
>   To: Aileen ; users at openlayers.org
>   Sent: Saturday, October 06, 2007 6:49 AM
>   Aileen: I'm assuming you're bumping your head against the URL
> configuration changes
>   that were made in 5.0. Virtually anything you could do in 4.10 is doable
> in 5.0 but the
>   mechanism may have changed. Can you pass along the URLs that are
> actually
> being
>   sent to MapServer? If so, then I can tell you what changes would be
> necessary to
>   make them work. Whether that means the OpenLayers interface will have to
> be updated
>   I'm not sure of.
>   Steve
>   >>> On 10/4/2007 at 9:41 PM, in message
> <003301c806f9$4bdda760$9601a8c0 at aileen>,
>   "Aileen" <aileen at mapcentral.ph> wrote:
>   > We recently upgraded our Mapserver version from 4.10 to 5.0.
>   > With that, we no longer can render lines and shade polygons.
>   > Did the parameter in passing variables from openlayers to mapserver
> changed?
>   > How do you send line parameters to mapserver?
>   > How will I render points and lines to CGI? What url do I use?
>   > Currently we use this:
>   > "/cgi-bin/mapserv?", {map: '/home/to/my/map.map', layer:'#qrylayer#',
>   > map_#qrylayer#:'classitem+#qryitem#+expression+#q.code#', format:
> 'gif',
>   > Aileen
