> A way to check might be to see if the loadingpanel example works for you or > not (this is against 2.6): > http://dev.openlayers.org/sandbox/bartvde/loadingpanel/examples/loadingpanel.html This example works with Safari: it's 2.6 based? In 2.6 LoadingPanel control is not present
