[OpenLayers-Users] Behaviour discrepancies between maps
(application/openlayers from GeoServer VS OpenLayers JS code)
Eric Lemoine
eric.c2c at gmail.com
Sun May 25 15:10:12 EDT 2008
Hello. Regarding the performance issue: in the first case three images
are requested from GS, one for each WMS layers configured in OL.
Althoug i'm not a GS expert, i think that in the second case only one
image is requested - the three layers are combined in a single image.
Does that make any sense ? Eric
2008/5/22, springrider <springrider at hotmail.com>:
> Hello,
> I tried to play with the different output format (gif,PNG8) but the display
> of the maps is always very slow when i zoom in. Moreover, i am still having
> this uncorrect display of the plolygons.
> If anyone could help a lost newbie, I would be very thankful...
> Sylvain
> springrider wrote:
>> Good afternoon
>> Sorry for the long title. I am developing a web application based on
>> oracle, GeoServer and Openalyers. It works great but i have found some
>> performance discrepancies and display problems between maps in a Web page
>> generated through OL Javascript code and maps generated from Geoserver
>> using the format="application/openlayers".
>> Here the code I am using to generate my map through JS code (Sorry
>> everything is on my development server and can not be accessed from
>> outside):
>> var myMap = new
>> OpenLayers.Map('mapResourceFIRMS',{numZoomLevels:24,projection:
>> "EPSG:4326" });
>> myMap.addControl(new
>> OpenLayers.Control.LayerSwitcher({'ascending':true}));
>> myMap.addControl(new OpenLayers.Control.OverviewMap());
>> var wms = new OpenLayers.Layer.WMS("All
>> Areas","http://193.43.36.236:8080/geoserver/wms?service=wms",
>> {layers:'fifao:FAO_DIVISION'},{wrapDateLine: true}
>> wms.addOptions({isBaseLayer: true});
>> var wms_continent = new
>> OpenLayers.Layer.WMS("Continent","http://193.43.36.236:8080/geoserver/wms?service=wms",
>> {layers: 'fifao:CONTINENTS_LN1',
>> transparent:"true"},{wrapDateLine: true}
>> wms_continent.addOptions({isBaseLayer: false});
>> myMap.addLayer(wms);
>> myMap.addLayer(wms_continent);
>> myMap.zoomToMaxExtent();
>> I obtain a map which works correctly but when i zoomed in, it always takes
>> 10 seconds to display the new extended view.
>> On this other hand, when i use the openlayer format of Geoserver through:
>> http://193.43.36.236:8080/geoserver/wms?bbox=-198.0,-97,198.0,99&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=fifao:FAO_DIVISION,fifao:CONTINENTS_LN1&width=600&height=290&srs=EPSG:4326
>> I obtain the same kind of map with less functionnalities but when i zoom
>> in, it is displayed automatically, very smoothly. No additional delay is
>> required to display the zoomed view.
>> Moreover i have a problem of display: When i zoom in on specific polygons
>> in the map based on OpenLayers JS library in my Web page, these polygons
>> are not correctly represented:
>> http://www.nabble.com/file/p17364274/Untitled-2%2Bcopy.jpg
>> : See in red the limits of the polygons which are missing.
>> Here, an screenshot of the same area from a map generated from Geoserver
>> using the "application/openlayers" format and having the correct border
>> for the polygons:
>> http://www.nabble.com/file/p17364274/Untitled-4%2Bcopy.jpg
>> I don't understand why 2 maps showing the same data which should be based
>> on the same mechanism, behave so differently in term of loading
>> performance and layers display. In fact, I would like to have my map
>> nested in my web page and built using Openlayers JS code behaving the same
>> as the one which can be generated through GeoServer.
>> Moreover, if you have any hints or tricks for improving the speed of
>> display when zooming, i would be very interested.
>> Hope it is clear enough.
>> Thanks
>> Sylvain
> http://www.nabble.com/Behaviour-discrepancies-between-maps-%28application-openlayers-from-GeoServer-VS-OpenLayers-JS-code%29-tp17364274p17410841.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
