[OpenLayers-Users] OpenLayers.Request problem; where is the data?
Lehtonen, Mika mika at digikartta.net
Mon Nov 3 15:42:35 EST 2008
Hi again,
using $_REQUEST (with your snippet), I get this. What's that?
array(2) {
  ["__utma"]=>
  string(54) "81555458.1737773788.1225666548.1225666548.1225666548.1"
  ["__utmz"]=>
  string(69) "81555458.1225666548.1.1.utmccn=(direct)|utmcsr=(direct)|utmcmd=(none)"
- mika -
Lehtonen, Mika kirjoitti:
> Hi Tim,
> tested that. I get this: array(0) { }
> I am trying to create a SLD on server side for Geoserver, based on what
> has been selected on client side. So I have quite a huge number (couple
> of thousands) of polygon regions of which an end user can choose from
> (with a "tool"). Chosen polygons should be presented with different
> style. So I decided to do that using wms. Unfortunately, if I create my
> SLD on client side and send it server by using GET, the request is way
> too long.
> Basically, an array of certain selected polygon attributes POSTED to
> server, would be enough.
> - mika -
> Tim Schaub kirjoitti:
>> Hey-
>> Can you write (preferably not all on one line) what you are doing again
>> to make the request?  If you are setting the content type, include that.
>>   Also, note that you can use the POST function and that you don't need
>> the new keyword.  In addition, note that params are about GET and data
>> is about POST.
>> I just set up PHP here and confirmed that the following works:
>>      var req = OpenLayers.Request.POST({
>>          url: "my.php",
>>          data: OpenLayers.Util.getParameterString({foo: "bar"}),
>>          headers: {
>>              "Content-Type": "application/x-www-form-urlencoded"
>> The content of my.php:
>>      <?php var_dump($_POST); ?>
>> What I see in the response:
>>      array(1) {
>>        ["foo"]=>
>>        string(3) "bar"
>> The same answer is given here:
>> http://openlayers.org/pipermail/users/2008-October/008483.html
>> I've put this example up on the Request wiki page:
>> http://trac.openlayers.org/wiki/Request#Ex.7:IssueaPOSTrequestwithform-encodeddata.
>> And, this is now a FAQ:
>> http://faq.openlayers.org/ajax/how-do-i-post-form-encoded-data/
>> Good luck,
>> Tim
>> Lehtonen, Mika wrote:
>>> Actually I already tested that. Also setting the Content-length and the
>>> Connection Close. I haven't been testing this with other browsers than
>>> FireFox. It seems that the POST method isn't responding in any way.
>>> Parameters attached to the request however seem to be working just fine.
>>> There was another issue, which might be the same you pointed to me, but
>>> the symtons are closer to mine:
>>> http://n2.nabble.com/OpenLayers.Request.POST-GET-errors-td1304742.html
>>> - mika -
>>> Arnd Wippermann kirjoitti:
>>>> Perhaps this solves the problem
>>>> headers: {
>>>>         "Content-Type": "application/x-www-form-urlencoded"}
>>>> http://n2.nabble.com/OpenLayers.Request-POST-and-IE-6-7-issues-tt1384863.htm
>>>> l#a1395114
>>>> Arnd Wippermann
>>>> -----Ursprüngliche Nachricht-----
>>>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
>>>> Auftrag von Lehtonen, Mika
>>>> Gesendet: Montag, 3. November 2008 10:01
>>>> An: OpenLayers
>>>> Betreff: [OpenLayers-Users] OpenLayers.Request problem; where is the data?
>>>> Hi,
>>>> I am trying to send a POST request from OL with the following snippet:
>>>> new OpenLayers.Request.issue({method: 'POST', url:'sld.php',
>>>> params:{abc:'def', cba:'fed'}, data:{ghi: 'jkl', ihg: 'lkj'},
>>>> success: function(){alert('Succeeded!');}, failure:
>>>> function(){alert('Did not succeed.');}, callback:
>>>> function(){alert('Calling back');}});
>>>> $_POST array in sld.php stays empty. In $_GET array I can find the
>>>> params: def and fed. How can I get touch with the data? Am I doing something
>>>> wrong here?
>>>> - mika -
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
> Users mailing list
