[OpenLayers-Users] OpenLayers+ExtJS 2.2
Tim Welch tim.j.welch at gmail.com
Mon Nov 3 16:43:16 EST 2008
Interesting that a link to my now aging proof of concept made it's way onto
the list.  :)
Carsten, I recommend checking out the MapFish project.  I simply used their
MapComponent widget that wraps the OL map object.  Those folks have made
great progress since I started trying to integrate and your better to start
with their basic examples.
Sorry I can't help you with your specific problem.  A better example of
Ext/OL integration here at Ecotrust is our ongoing MarineMap project to aid
in the designation of marine protected areas in Southern California.
http://marinemap.org/marinemap.
OL and Mapfish, you guys make it possible.  Thank you for your work.
Tim
Tim Welch
Applications Developer
ecotrust
On Mon, Nov 3, 2008 at 7:27 AM, <bartvde at osgis.nl> wrote:
> Do you have an example showing the problem?
> Best regards,
> Bart
> > I experienced similiar problems whenuisng jquery !
> > Dipl. Inf. Carsten Eider schrieb:
> >> Hi folks,
> >> as mentioned in
> http://workshops.opengeo.org/openlayers/intro/doc/integration.html#exploring-ext-js
> >> there is a possibility to setup up an application
> >> where openlayers and ExtJS 2.2 work together.
> >> While searching this list I found a link to
> >> http://pearl.ecotrust.org/~twelch/apps/odfw/app.html<http://pearl.ecotrust.org/%7Etwelch/apps/odfw/app.html>,
> showing a
> >> working example.
> >> my problem is:
> >>     * while loading my page the error "evt.layer.events has no
> >>       properties/evt.layer.events.register('loadstart', this,
> >>       this.increaseCounter);" in LoadingPanel.js(50) occurs
> >>     * when removing Loadingpanel_Control the error "layer.div has no
> >>       properties/layer.div.className = "olLayerDiv";" Map.js(816)
> >> occurs
> >> and my map doesn't work any more
> >> Any suggestions?
> >> Mit freundlichen Grüßen / Yours faithfully
> >> Carsten Eider
> >> Dipl. Inf. (FH)
> >> Kompetenzzentrum für Innovative Informationssysteme
> >> c/o Fachhochschhule Bingen / University of applied sciences Bingen
> >> Berlinstraße 109
> >> 55411 Bingen
> >> Tel: +49 (0) 6721 / 409-179
> >> Fax: +49 (0) 6721 / 409-158
> >> email: eider at fh-bingen.de
> >> Internet: iis.fh-bingen.de
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Carsten Eider
> > Dipl. Inf. (FH)
> > Berlinstraße 109
> > 55411 Bingen
> > Users mailing list
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081103/21839d30/attachment.html
