[OpenLayers-Users] All vector features in one WFS layer
Alexandre Dube adube at mapgears.com
Tue Nov 4 14:09:09 EST 2008
We found a workaround ( thanks to my colleagues Daniel and Julien ).
  My data is originally from MapInfo.  I just opened each table to add a
column named "Type" and gave a unique value for each one.  Then, in OL,
used the addUniqueValueRules using the new "Type" attribute they all share.
  Manipulate data is a harsh way ( in my opinion ), but it works so why
bother ?
Alexandre
Alexandre Dube wrote:
> Hi list,
>   I have some data from different sources I want to put in the same WFS
> vector layer to be able to interact with all of them at the same time.
> I would like to give each source a single unique style.  I know how to
> do that with a single source of data using addUniqueValueRules function,
> but I would like something more like "if this features comes from that
> source, draw using this style", or like "if this feature as an
> attributes called something, draw with this style".  Is that possible ?
>   Also, I would like each source to be in the layerSwitcher.  What I
> thought so far to resolve that is creating a dummy layer for each
> source, register a "onVisibilityChange" event that would change the
> "style" to nothing if uncheck ( or to its original style on check ) and
> redraw the whole layer.  I think that could do it, but I would be long
> to redraw everything every time.  Any thought ?
>   I saw the "One Single - Mother of all vector" example, but don't think
> it can helps here.  I need to figure a way to give a unique style for
> each data source...
>   An other option could be to create a WFS layer for each data source (
> as normal ) and add a little control panel to toggle which one is on
> top.  But I would prefer my first option ( if possible ).
>   Anybody have any better idea ?
>   Are my ideas ok ?
>   Can I give a unique style for each data source ?
Alexandre Dubé
Mapgears
www.mapgears.com
