[OpenLayers-Users] FEATUREID vs. BBOX in GetFeature for WFS
Gissur Þórhallsson gissur at loftmyndir.is
Tue Nov 4 20:23:12 EST 2008
Yeah, I actually use a proxy script as well, I guess I'll do that then.
Thanks for the pointer, I was so certain this could be done easily inside
the OL API that I hadn't yet started thinking about hacking at it. I guess
I'll make do with hacking the URL at the proxy until this gets resolved.
Thank you both for your answers :)
Kind regards from Iceland,
Gissur
On Mon, Nov 3, 2008 at 5:25 PM, Arnd Wippermann <arnd.wippermann at web.de>wrote:
>  if you use a proxy script to request your data, you can there modify the
> request before you send it to the server. I do this, to be able to use
> FILTER instead of BBOX.
> Arnd Wippermann
>  *Von:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *Im Auftrag von *Gissur Þórhallsson
> *Gesendet:* Montag, 3. November 2008 17:48
> *An:* users at openlayers.org
> *Betreff:* [OpenLayers-Users] FEATUREID vs. BBOX in GetFeature for WFS
> Hi there,
> I'm using OpenLayers.Layers.WFS.mergeNewParams(...) to retrieve some GML
> from the server according to a FEATUREID that I've already procured.
> The problem is that the request tells me the following:
> GetFeature KVP request contained conflicting filters. Filter: null, fid:
> lmi_flakar_nafn.396,
> bbox:571406.48554375,565489.84275125,590692.1336562501,579265.3056887499
> Which I understand, since these two filters (FEATUREID and BBOX) are
> mutually exclusive.
> My question, on the other hand, is how can I remove the BBOX parameter from
> the request?
> I can't seem to find it in the docs anywhere.
> Any ideas?
> Kind thanks from Iceland,
> Gissur
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081105/e1c16ce1/attachment.html
