[OpenLayers-Users] Map Labels Problem
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Fri Nov 7 09:54:02 EST 2008
I think that you have a problem with the ordering of your layers.  I
think you need to put your raster at the beginning of your mapfile,
instead of the end.
HTH,
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Kusum
Sent: Thursday, November 06, 2008 8:44 AM
To: Openlayers Users
Subject: [OpenLayers-Users] Map Labels Problem
Dear All
I am trying to use mercator projection in my mapfile.
Also I am using a raster image along with my shp data
At first level it does not show the raster image
But when it does it hides the labels on map.
u can see this link
http://mapxl.com/interactive-maps/world-map11.php
I am confused
my map file is
MAP
EXTENT -180 -90 180 90
UNITS MILES
SIZE 550 450
SHAPEPATH "/home/mapxlco/public_html/World-Data"
FONTSET "./etc/fonts.txt"
RESOLUTION 96
IMAGETYPE png
INTERLACE OFF
PROJECTION
"proj=merc"
 #'init=EPSG:3785'
END
OUTPUTFORMAT
  NAME png
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE RGB
  FORMATOPTION  INTERLACE=OFF
  TRANSPARENT OFF
END
 WEB
  TEMPLATE "legend.php"
  HEADER "map_header.html"
  FOOTER "map_footer.html"
  #IMAGEPATH "C:/ms4w/apps/maplab-2.2/workshop/tmp/"
  #IMAGEURL "../tmp/"
  IMAGEPATH "/home/mapxlco/public_html/tmp/"
  IMAGEURL "/tmp/"
  METADATA
  END  # Metadata
END
#World_Background
LAYER
    NAME "background"
    STATUS DEFAULT
    PROJECTION
 #"init=epsg:3785"
    END
    TYPE POLYGON
    DATA "background"
    TOLERANCE 300
    #CLASSITEM "COUNTRIES"
    CLASS
 NAME "World Background"
 COLOR 141 189 232
        OUTLINECOLOR 111 157 253
 Template void
    END
END
#World Continents
LAYER
    NAME "continents"
    STATUS DEFAULT
    PROJECTION
 #"init=epsg:3785"
    END
    TYPE POLYGON
    DATA "World_Continents"
    MINSCALE 1500000
    LABELMAXSCALE 2500000
    LABELMINSCALE 1430359
    LABELITEM "CONTINENT"
    TOLERANCE 300
    CLASSITEM "CONTINENT"
    CLASS
 NAME "World Outline"
 EXPRESSION "Europe"
 #COLOR 241 238 232
 COLOR 235 240 230
 LABEL
   ANGLE auto
          ANTIALIAS TRUE
          FONT arial
          MAXSIZE 256
          MINSIZE 4
          SIZE 10
          TYPE TRUETYPE
          BUFFER 0
          COLOR 0 0 0
          FORCE TRUE
          MINDISTANCE 0
          MINFEATURESIZE 0
          OFFSET 0 10
          OUTLINECOLOR 255 255 255
          PARTIALS FALSE
          POSITION LL
        END
        Template void
    END
    CLASS
 EXPRESSION "North America"
 #COLOR 241 238 232
 COLOR 235 240 230
 LABEL
   ANGLE auto
          ANTIALIAS TRUE
          FONT arial
          MAXSIZE 256
          MINSIZE 4
          SIZE 10
          TYPE TRUETYPE
          BUFFER 0
          COLOR 0 0 0
          FORCE TRUE
          MINDISTANCE 0
          MINFEATURESIZE 0
          OFFSET 20 10
          PARTIALS FALSE
          POSITION LR
        END
        Template void
    END
    CLASS
 #COLOR 241 238 232
 COLOR 235 240 230
 LABEL
   ANGLE auto
          ANTIALIAS TRUE
          FONT arial
          MAXSIZE 256
          MINSIZE 4
          SIZE 10
          TYPE TRUETYPE
          BUFFER 0
          COLOR 0 0 0
          FORCE TRUE
          MINDISTANCE 0
          MINFEATURESIZE 0
          OFFSET 0 0
          PARTIALS FALSE
          POSITION CC
        END
        Template void
    END
END
#World Countries
LAYER
    NAME "countries"
    STATUS DEFAULT
    MAXSCALE 1530359
    LABELMAXSCALE 1430359
    PROJECTION
 #"init=epsg:3785"
    END
    TYPE POLYGON
    DATA "World_Countries"
    LABELITEM "NA2DESC"
    TOLERANCE 300
    CLASSITEM "NA2DESC"
    CLASS
 NAME "World Countries"
 #COLOR 241 238 232
 COLOR 235 240 230
        OUTLINECOLOR 220 220 220
 LABEL
   ANGLE auto
          ANTIALIAS TRUE
          FONT arial-bold
          MAXSIZE 256
          MINSIZE 4
          SIZE 9
          TYPE TRUETYPE
          BUFFER 0
          COLOR 90 90 90
          MINDISTANCE 0
          MINFEATURESIZE 30
          OFFSET 0 0
          PARTIALS FALSE
          POSITION CC
   FORCE FALSE
   wrap ' '
        END
        Template void
    END
END
#World_Background
LAYER
    NAME "background1"
    STATUS ON
    PROJECTION
 "proj=latlong"
  END
    TYPE RASTER
    DATA "wsiearth.tif"
    TEMPLATE "ttt.html"
END
#Countries Boundary
LAYER
    NAME "countries"
    STATUS DEFAULT
    MAXSCALE 1430359
    PROJECTION
 #"init=epsg:3785"
    END
    TYPE LINE
    DATA "Country_Boundary"
    TOLERANCE 300
    #CLASSITEM "CONTINENT"
    CLASS
 #COLOR 204 225 253
        OUTLINECOLOR 167 167 167
 Template void
    END
END
so on..........
I am not getting the palce of error
Please suggest.
Regards
Kusum
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081107/44a236fd/attachment.html
