[OpenLayers-Users] How to add two clickable buttons? (OpenLayers.Control.Button)
Lehtonen, Mika mika at digikartta.net
Wed Nov 12 16:08:48 EST 2008
Hi again Harry,
I became curious. You have to learn something new every day, they say.
Please try this: (by setting ItemInactive / ItemActive, you can control
the button's look on activity basis. Just create separate styles for
them and change it by button.activate/deactivate)
cheers,
- mika -
        .olControlPanel div {
          float: left;
                display: block;
                position: relative;
          left: 60px;
          margin-left: 10px;
          margin-top: 10px;
          width:  36px;
          height: 19px;
          border: 1px solid RED;
        .olControlPanel .button1DisplayItemInactive {
          width:  36px;
          height: 19px;
          background-image: url("./mybutton1.png");
        .olControlPanel .button2DisplayItemInactive {
          width:  36px;
          height: 19px;
          background-image: url("./mybutton2.png");
Harry Wood kirjoitti:
> I'm trying to add two clickable buttons (OpenLayers.Control.Button). Should be easy enough. Here's how far I've got: http://funmap.co.uk/openlayers-test/buttons.html  (code below)
> For some reason having the css class 'olControlPanel' causes it to almost work, but this is a mystery to me (copied off some other example) and as the red borders demonstrate, I don't seem to have much control over where these click regions go.
> I suspect I'm barking up the wrong tree with that. There should be a much easier way of getting the click events to call my functions. OpenLayers.Function.bind perhaps, but I can't work out how to call this.
> Any pointers much appreciated.
> Harry Wood
> http://harrywood.co.uk
> Here's my html:
> <html>
>   <head>
>     <title>OpenLayers buttons experiment</title>
>     <script src="http://openlayers.org/api/OpenLayers.js" type="text/javascript"></script>
>     <script src="http://openstreetmap.org/openlayers/OpenStreetMap.js" type="text/javascript"></script>
>     <style>
>         .button1Display {
>           margin-left: 60px;
>           margin-top: 10px;
>           width:  36px;
>           height: 19px;
>         .button2Display {
>           margin-left: 110px;
>           margin-top: 10px;
>           width:  36px;
>           height: 19px;
>         /* olControlPanel is a mysterious css class of elements which seem to catch button click events */
>           margin-left: 60px;
>           margin-top: 10px;
>           width:  36px;
>           height: 19px;
>         #map {
>           border: 1px solid #222;
>           width: 300px;
>           height: 300px;
>     </style>
>     <script type="text/javascript">
>         var map;
>         var layerMapnik = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
>         var layerMaplint = new OpenLayers.Layer.OSM.Maplint("Maplint")
>         var layerTah = new OpenLayers.Layer.OSM.Osmarender("Tiles at Home");
>         var layerMarkers = new OpenLayers.Layer.Markers("POIs");
>         function myFunction1() {
>             alert('myFunction1');
>         function myFunction2() {
>             alert('myFunction2');
>         function init(){
>             map = new OpenLayers.Map('map', {
>                       maxExtent: new OpenLayers.Bounds(-20037508,-20037508,20037508,20037508),
>                       numZoomLevels: 18,
>                       maxResolution: 156543,
>                       units: 'm',
>                       projection: "EPSG:41001"
>             map.addLayers([layerMapnik, layerMaplint, layerTah, layerMarkers]);
>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>             var panel = new OpenLayers.Control.Panel();
>             var button1 = new OpenLayers.Control.Button({title:'title1',
>                                                         displayClass: "button1Display",
>                                                         trigger: myFunction1});
>             var button2 = new OpenLayers.Control.Button({title:'title2',
>                                                         displayClass: "button2Display",
>                                                         trigger: myFunction2});
>             panel.addControls([button1,button2]);
>             map.addControl(panel);
>             var lat=51.508;
>             var lon=-0.118;
>             var zoom=8;
>             var lonLat = new OpenLayers.LonLat(lon, lat).transform(new OpenLayers.Projection("EPSG:4326"), map.getProjectionObject());
>             map.setCenter (lonLat, zoom);
>     </script>
>   </head>
>   <body onload="init()">
>     <div id="map" width="400px" height="400px"></div>
>   </body>
> </html>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
